[postgis-users] Database restarting while using ST Functions
Pradeep Kanth G pgundala at avineonindia.com
Tue Feb 6 04:08:25 PST 2018
Thanks Daniel,
It is a PostGIS 2.1.9  (EDB 9.5),after upgrading to PostGIS 2.3(EDB 9.5) this issue has been resolved.
However , we are testing EDB Development version 9.5.And there is no compatible with PostGIS 2.3 it will support only 2.1.9. So kindly let me know how to overcome this issue on 2.1.9.
Regards
Pradeep Kanth
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Daniel Baston
Sent: Tuesday, February 6, 2018 5:13 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Database restarting while using ST Functions
Hi Pradeep,
Try checking the output of "SELECT postgis_full_version()". If you're not at the latest point-release, you should upgrade. There have been memory handling bugs with ST_CollectionHomogenize that could maybe cause the issue you're seeing.
Dan
On Tue, Feb 6, 2018 at 5:59 AM, Pradeep Kanth G <pgundala at avineonindia.com <mailto:pgundala at avineonindia.com> > wrote:
Dear All,
Kindly raise the below issue with EDB.
Observation :  Database restarting while using  ST Functions.
Issue :   Intersecting with two geometries, while using ST_Intersects and ST_CollectionHomogenize functions
Database is restarting automatically.
Example: ST_Intersects(ST_CollectionHomogenize(p.geometry,c.geometry))
Screenshot:
Regards
Pradeep Kanth
Disclaimer | The information contained in this electronic message (including any attachments) is intended for the exclusive use of the addressee(s) and may contain confidential or privileged information.If you have received this in error, please notify the sender immediately and delete the material from your machine. Any  action including review, retransmission, dissemination of this email or the attachments present along with the email by persons or entities other than the intended recipient is prohibited.
postgis-users mailing list
postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180206/188a8d21/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180206/188a8d21/attachment.png>
