[postgis-users] WORKAROUND: Restore of PostgreSQL/PostGIS Database fails with functional Index on ST_Transform
Regina Obe
lr at pcorp.us
Wed Jan 17 09:26:17 PST 2018
This issue should be fixed in newly released PostGIS 2.4.3
So if you pg_restore on a PostGIS 2.4.3, no set search path should be needed anymore.
Thanks,
Regina
-----Original Message-----
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Wednesday, January 17, 2018 12:11 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] WORKAROUND: Restore of PostgreSQL/PostGIS Database fails with functional Index on ST_Transform
Remember to
ALTER FUNCTION ST_Transform(geometry, INTEGER) RESET search_path;
when you are done your restore, or all your calls to ST_Transform() will have a 4x performance penalty.
P
On Wed, Jan 17, 2018 at 8:56 AM, schild <andreas.schild at bfw.gv.at> wrote:
> Hi all,
> Migration of a PostGIS database via pg_restore induces an error, if the database includes a functional index on ST_Transform:
> [postgres ~] $ pg_restore --username=postgres --dbname=mydb --verbose --no-tablespaces --index=mygeom_etrs89laea_gist "mydb.backup"
> => Error Message (see below)
> Workaround:
> mydb=# ALTER FUNCTION ST_Transform(geometry, INTEGER) SET
> search_path=public;
> pg_restore: connecting to database for restore
> pg_restore: creating INDEX "myschema.mygeom_etrs89laea_gist "
> Greetings from Vienna,
> Andreas
> Error Message:
> pg_restore: creating INDEX "myschema.mygeom_etrs89laea_gist"
> pg_restore: [archiver (db)] Error while PROCESSING TOC:
> pg_restore: [archiver (db)] Error from TOC entry 17844; 1259 443698 INDEX mygeom_etrs89laea_gist postgres
> pg_restore: [archiver (db)] could not execute query: ERROR: relation
> "spatial_ref_sys" does not exist LINE 1: SELECT proj4text FROM spatial_ref_sys WHERE srid = 31287 LIM...
> QUERY: SELECT proj4text FROM spatial_ref_sys WHERE srid = 31287 LIMIT 1
> Command was: CREATE INDEX mygeom_etrs89laea_gist ON mygeom USING
> gist (public.st_transform(geom, 93035));
> mydb=# SELECT version();
> PostgreSQL 10.1 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 7.2.0,
> 64-bit
> mydb=# SELECT postgis_full_version();
> POSTGIS="2.4.2 r16113" PGSQL="100" GEOS="3.6.2-CAPI-1.10.2 4d2925d6"
> PROJ="Rel.4.9.3, 15 August 2016" GDAL="GDAL 2.2.3, released 2017/11/20"
> LIBXML="2.9.7" LIBJSON="0.13" LIBPROTOBUF="1.3.0" TOPOLOGY RASTER
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
