[postgis-users] [postgis-devel] Problem in st_StriaghtSkeleton - Hangs!
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jan 18 06:43:50 PST 2018
On 1/18/2018 3:54 AM, Martijn Meijers wrote:
> Hi,
> I think the problem with this input is that there is *a lot* of parallel
> lines, meaning that in the algorithm of skeleton construction many
> things happen at exactly the same time (if you see it as a wavefront
> propagation). I also tried with my Python implementation [1], but this
> also crashes (-:
> One option I'd try is to slightly perturb/add some randomness to your
> input coordinates (to take away the lines being exactly parallel) and
> see if that goes through...
This data is generated from a scan of a building floor plan by passing
it through st_dumpaspolygons(rast, 1, true) so it will always have lots
of parallel lines. This is just one of ten similar drawings but its the
only one that fails. I'll be running a larger set today and may have
some additional failures.
I tried Regina's suggestion of using ST_ApproximateMedialAxis and
ST_SubDivide but that also seems to hang in my work flow. I'll take
another look through my queries to make sure I incorporated it correctly.
How would you go about perturbing the input coordinates?
Thanks,
-Steve
> Martijn
> [1] https://bitbucket.org/bmmeijers/grassfire/
> On 18-01-18 02:21, Stephen Woodbridge wrote:
>> Hi Regina,
>> Thanks, this is a great idea. I rework my queries to work in
>> ST_ApproximateMedialAxis and ST_SubDivide and see how that does.
>> -Steve
>> On 1/17/2018 8:13 PM, Regina Obe wrote:
>>> Steve,
>>> One more thought. Can you try this and see if it works. I think
>>> ST_StraightSkeleton and ST_ApproximateMedialAxis are having issues,
>>> because in this case your holes are so big that it almost cuts into
>>> another.
>>> So to work around the issue, you can subdivide the polygon and then
>>> do the analyze like this:
>>> SELECT ST_ApproximateMedialAxis(ST_SubDivide('POLYGON((256 760,518
>>> 760,518 630,674 630,674
>>> 239,673 239,127 239,127 240,126 240,126 513,127 513,127 514,126 514,126
>>> 630,255 630,256 630,256 760),(128 629,128 423,270 423,270 422,271
>>> 422,271 240,672 240,672 629,128 629),(258 759,258 631,516 631,516
>>> 759,258 759),(128 421,128 240,269 240,269 421,128 421))'::geometry,
>>> 12));
>>> You might need to tweak with the subdivide param.
>>> http://postgis.net/docs/manual-dev/ST_Subdivide.html
>>> The subdivide cuts right into the holes turning them not into holes
>>> so you end up with simple polygons that approximate medial axis can
>>> handle.
>>> Once you are done you can run ST_Union on your set of Linestrings.
>>> -----Original Message-----
>>> From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On
>>> Behalf Of Stephen Woodbridge
>>> Sent: Wednesday, January 17, 2018 2:47 PM
>>> To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
>>> Subject: [postgis-devel] Problem in st_StriaghtSkeleton - Hangs!
>>> Hi all,
>>> I have run into a problem using st_StraightSkelton() where it appears
>>> to hang at 100 cpu. Maybe an endless loop?
>>> select st_straightskeleton('POLYGON((256 760,518 760,518 630,674 630,674
>>> 759,258 759),(128 421,128 240,269 240,269 421,128 421))'::geometry);
>>> POSTGIS="2.3.3 r15473" GEOS="3.5.1-CAPI-1.9.1 r4246" SFCGAL="1.2.2"
>>> PROJ="Rel. 4.9.2, 08 September 2015" GDAL="GDAL 1.11.3, released
>>> 2015/09/16" LIBXML="2.9.3" LIBJSON="0.11.99" RASTER
>>> Can anyone reproduce this?
>>> Any idea how to work around it?
>>> Is there a non-CGAL version of skeleton?
>>> Thanks,
>>> -Steve
>>> This email has been checked for viruses by Avast antivirus software.
>>> https://www.avast.com/antivirus
>>> postgis-devel mailing list
>>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
