[postgis-users] Spatial Intersect if condition is met then go to next step
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Mon Jan 29 05:14:35 PST 2018
hi,
you may employ `where exists()`:
select seq from tst sq
WHERE EXISTS(select from present_mapnonclipped.gde_polygons ss
where ss.seq = sq.seq and ST_Intersects(ss.geom,envelope)) or
exists(present_mapnonclipped.gde_polygons ss
You may also want to debug your query with EXPLAIN (ANALYZE, VERBOSE,
BUFFERS) before putting it into stored procedure.
пн, 29 янв. 2018 г. в 14:04, Oliver Morris <Oliver.Morris at halliburton.com>:
> Hi,
> First post so apologies in advance if this is the wrong place for this
> question – hopefully I found the right place.
> I have a bounding box geometry and I would like to find out if any rows in
> a selection of tables are intersected, each table contains a field (seq)
> which contains a property that I need to group the results by (for this
> demo lets day it is days of the week). I don’t need to know how many rows
> but simply require a true/false result for each table and seq. Ideally the
> script as soon as it has found an intersection would move onto the next
> table and not spend any further time running intersections, I was hoping
> the limit 1 clause would do this. I was also hoping that the lateral join
> would help me to do the grouping but I think it still processes all the
> rows.
> Currently my script (for two example tables) looks like:
> CREATE OR REPLACE FUNCTION tst.f_tst_report(
> topleftx double precision,
> toplefty double precision,
> bottomrightx double precision,
> bottomrighty double precision,
> groupidarray text)
> RETURNS TABLE(seq character)
> LANGUAGE 'plpgsql'
> COST 100
> VOLATILE
> ROWS 1000
> AS $BODY$
> DECLARE
> envelope geometry;
> BEGIN
> envelope :=
> ST_MakeEnvelope(topleftx,toplefty,bottomrightx,bottomrighty,4326);
> RETURN QUERY
> WITH
> cte_gde_polygons as (
> select distinct sq.seq as seq1 from tst.seq sq
> join lateral (
> select ss.seq from present_mapnonclipped.gde_polygons ss
> limit 1
> ) p on true),
> cte_gde_fault as (
> join lateral (
> select ss.seq from present_mapnonclipped.gde_fault ss
> limit 1
> ) p on true)
> select * from cte_gde_polygons
> union
> select * from cte_gde_fault
> END
> $BODY$;
> An example output across these tables for when Monday, Wednesday and
> Thursday intersects with the bounding box would return:
> Seq
> Monday
> Wednesday
> Thursday
> In short - if there is no way to stop intersecting after the first match
> my alternative is to dissolve all the features by seq in each table. The
> only issue would be that this would need updating on any data change.
> Many Thanks for your help in advance,
> Oliver
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180129/31e89949/attachment.html>
