[postgis-users] Change the type in geometry_columns
Daniel Baston dbaston at gmail.com
Wed Jul 11 07:25:25 PDT 2018
Hello Bryan,
You should be able to control this by setting "Create Generic Geometry
Columns" to "No" in the settings for your PostGIS writer:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/postgis/PostGIS_writer.htm
Dan
On Wed, Jul 11, 2018 at 10:14 AM Bryan Hall <bryan.hall at chk.com> wrote:
> Is it possible to change the type attribute in the geometry_columns view?
> All the data I am migrating with FME from Oracle is being set to GEOMETRY
> and I’d like to set it to the appropriate type if possible.
> I didn’t see anything in the manual on how to do that post 2.0 (if it is
> still possible).
> Thanks in advance…
> This email (and attachments if any) is intended only for the use of the
> individual or entity to which it is addressed, and may contain information
> that is confidential or privileged and exempt from disclosure under
> applicable law. If the reader of this email is not the intended recipient,
> or the employee or agent responsible for delivering this message to the
> intended recipient, you are hereby notified that any dissemination,
> distribution or copying of this communication is strictly prohibited. If
> you have received this communication in error, please notify the sender
> immediately by return email and destroy all copies of the email (and
> attachments if any).
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180711/5b0d294b/attachment.html>
