[postgis-users] Convert Box3D to TIN geometries
Darafei "Komяpa" Praliaskouski me at komzpa.net
Tue Jul 24 11:31:25 PDT 2018
Hi Tom,
You can copy the triangulated from my message Box and ST_Translate /
ST_Scale it using ST_{X,Y,Z}{Min,Max} of your box. Of course, more
preferable way would be to use SFCGAL extension, as it's part of PostGIS :)
вт, 24 июл. 2018 г. в 16:09, Tom Kazimiers <tom at voodoo-arts.net>:
> That's nice indeed, thanks for the update!
> I suppose there is no way to convert a Box3D to a TIN geometry without
> SFCGAL in a similar fashion? Specifiying vertices and triangles using
> ST_{X,Y,Z}{Min,Max} is no problem, it only gets pretty verbose and we can't
> add SFCGAL to our dependencies at the moment.
> Cheers,
> Tom
> On July 24, 2018 10:20:09 AM UTC, Felix Kunde <felix-kunde at gmx.de> wrote:
>> I was hoping for a news like this. Great. Thanks!
>> Gesendet: Montag, 23. Juli 2018 um 20:17 Uhr
>> Von: "Darafei \"Komяpa\" Praliaskouski" <me at komzpa.net>
>> An: "PostGIS Users Discussion" <postgis-users at lists.osgeo.org>
>> Betreff: Re: [postgis-users] Convert Box3D to TIN geometries
>> Hi Felix,
>> This was fixed in PostGIS 2.5.
>> There your query ends up with geometry like this:
>>  GEOMETRYCOLLECTION Z (TIN Z (((0 0 0,0 1 0,1 1 0,0 0 0)),((1 0 0,0 0 0,1 1 0,1 0 0)),((0 1 1,1 0 1,1 1 1,0 1 1)),((0 1 1,0 0 1,1 0 1,0 1 1)),((0 0 0,0 0 1,0 1 1,0 0 0)),((0 1 0,0 0 0,0 1 1,0 1 0)),((1 0 1,1 1 0,1 1 1,1 0 1)),((1 0 1,1 0 0,1 1 0,1 0 1)),((0 0 1,1 0 0,1 0 1,0 0 1)),(
>> (0 0 1,0 0 0,1 0 0,0 0 1)),((0 1 0,0 1 1,1 1 1,0 1 0)),((1 1 0,0 1 0,1 1 1,1 1 0))))
>> ср, 18 июл. 2018 г. в 11:21, Felix Kunde <felix-kunde at gmx.de[mailto:felix-kunde at gmx.de]>:Hi,
>> thought that's easy to do with the postgis_sfcgal extension, but no:
>> SELECT ST_Tesselate('BOX3D(0 0 0,1 1 1)'::box3d::geometry));
>> ERROR: Solid is invalid : PolyhedralSurface (shell) 0 is invalid: not connected : SOLID((((0/1 0/1 0/1,0/1 1/1 0/1,1/1 1/1 0/1,1/1 0/1 0/1,0/1 0/1 0/1)),((0/1 0/1 1/1,0/1 1/1 1/1,1/1 1/1 1/1,1/1 0/1 1/1,0/1 0/1 1/1)),((0/1 0/1 0/1,0/1 1/1 0/1,0/1 1/1 1/1,0/1 0/1
>> SQL Status:XX000
>> The polygons are not in the right order :-/
>> Also tried dumping and delaunay triangulation but yet not solution. Anyone else?
>> Cheers,
>> Felix
>> Gesendet: Dienstag, 17. Juli 2018 um 20:04 Uhr
>> Von: "Tom Kazimiers" <tom at voodoo-arts.net[mailto:tom at voodoo-arts.net]>
>> An: postgis-users at lists.osgeo.org[mailto:postgis-users at lists.osgeo.org]
>> Betreff: [postgis-users] Convert Box3D to TIN geometries
>> Hi all,
>> I need to convert a lot of Box3D geometries to TIN geometries. Is there a way in PostGIS to do this without specifiying each triangle and vertex for the new TINs explicitly? Idealy, I would just be able to issue a simple update statement without needing to think about vertex order and triangle order.
>> Thanks,
>> Tom
>> postgis-users mailing list postgis-users at lists.osgeo.org[mailto:postgis-users at lists.osgeo.org] https://lists.osgeo.org/mailman/listinfo/postgis-users
>> https://lists.osgeo.org/mailman/listinfo/postgis-users--
>> Darafei Praliaskouski
>> Support me: http://patreon.com/komzpa[http://patreon.com/komzpa]
>> postgis-users mailing list postgis-users at lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/postgis-users[https://lists.osgeo.org/mailman/listinfo/postgis-users]
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180724/d5570d08/attachment.html>
