[postgis-users] When PostGIS is used with pg_store_plans, OutOfMemory occurs.
Paul Ramsey
pramsey at cleverelephant.ca
Mon Mar 5 06:42:52 PST 2018
Confirmed.
Ticketed at https://trac.osgeo.org/postgis/ticket/4036
I recommend you carry the problem over to pg_store_plans, as the OOM
is happening in their code, not in ours.
P.
On Sun, Mar 4, 2018 at 9:29 PM, Kariatsumari, Kazuki
<ka.kariatsumari at jp.fujitsu.com> wrote:
> Dear all.
> To the DB of the environment where pg_store_plans is enabled,
> Attempting to enable PostGIS will result in OutOfMemory.
> Is this phenomenon specification?
> The steps that occurred are described below.
> 1. Install PostGIS.
> 2. Install pg_store_plans.
> 3. Write pg_store_plans in shared_preload_libraries in postgresql.conf.
> 4. Restart Postgresql.
> 5. Connect to DB.
> 6. Execute "CREATE EXTENTION postgis".
> Thanks,
> Kazuki Kariatsumari
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
