[postgis-users] Error upgrading to PostGIS 2.4.3
Regina Obe lr at pcorp.us
Wed Mar 21 10:18:06 PDT 2018
Yah the libxml2.dll and I assume you meant libxml2-2.dll.  PostGIS needs the
one called libxml2-2.dll and PostgreSQL EDB uses the one called libxml2.dll.
They can be even the same dll.  The libxml2-2.dll I have is dated 7/17/2017
(but like I said if you copied libxml2.dll to libxml2-2.dll that should work
fine.
I upgraded my PostgreSQL 9.6 to EDB 9.6.8 and the 2.4.3 I had installed was
still working so libeasy is not the issue.  I too also have libeay32.dll
(1.0.2n, 12/12/2017)
You copied over the binaries?  You weren't using the installer?  For some
reason on my server, the Stackbuilder hung trying to download the installer
so I just got it from:
https://winnie.postgis.net/download/windows/pg96/buildbot/postgis-bundle-pg9
6x64-setup-2.4.3-2.exe
I still haven't got around to installing on a virgin 9.6.8.  To rule out
it's not just because I've got some other libraries I always use already
installed on my EDb instance.
Thanks,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of McDonaldR
Sent: Wednesday, March 21, 2018 11:54 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Error upgrading to PostGIS 2.4.3
Hi Regina
Thanks for the feedback.
This is my current working environment:
"POSTGIS="2.3.5 r16110" GEOS="3.6.2-CAPI-1.10.2 4d2925d" PROJ="Rel. 4.9.3,
15 August 2016" GDAL="GDAL 2.2.2, released 2017/09/15" LIBXML="2.7.8"
LIBJSON="0.12" TOPOLOGY RASTER PostgreSQL 9.6.8, compiled by Visual C++
build 1800, 64-bit"
I stopped PostgreSQL, copied over the new PostGIS binary files, restarted
PostgreSQL and tried to run the upgrade.
I have libeay32.dll (1.0.2n, 12/12/2017) installed in bin\ as well as
libxml2.dll and linxml2-2.dll (should I have both files?)
Ross
Of Regina Obe
Sent: 20 March 2018 23:36
To: 'PostGIS Users Discussion'
Ross,
That error often means there is a dependency missing.
I think I did upgrade some binaries like GDAL and GEOS in last run, so if
you were upgrading while PostGIS lib was in use, you might have gotten an
error like
"Can't overwrite file"  during installation and since 2.4.3 would need the
newer GDAL/GEOS/Proj might fail.  That would cause this problem.  Fix would
be shut down postgresql, restart and rerun the 2.4.3 setup.
Could also be a packaging mistake on my part.
I'll test on my end on a clean 64-bit 9.6.8 to rule out issue on my end.
Last time I had a large number of people complaining about this, it was
because EDB micro upgraded installed a libeasy32.dll that was incompatible
with the curl I was shipping, so I had to recompile the curl to be
compatible with whatever EDB upgraded their SSL libraries to.
Given your 2.3.5 still works?  I assume the ssl is not the issue.
Thanks.
Regina
Of McDonaldR
Sent: Tuesday, March 20, 2018 2:00 PM
<mailto:postgis-users at lists.osgeo.org> >
Subject: [postgis-users] Error upgrading to PostGIS 2.4.3
Hi List
Maybe you can point me in the right direction.  I'm running PostgreSQL 9.6.8
(64bit) on Windows 2008 R2 with PostGIS 2.3.5 installed.  I have installed
the 2.4.3 binaries and when I try to run ALTER EXTENSION postgis UPDATE TO
"2.4.3"; I get the following error:
ERROR could not load library PostgreSQL/9.6/lib/postgis-2.4.dll The
specified procedure could not be found.
The file is there.  I've checked permissions and all are valid.  I've
stopped and started the postgresql service.  Am I missing something going
from PostGIS 2.3.x to 2.4.x?  In the past upgrades have been totally
painless.
Any help much appreciated.
Thanks
Ross
Ross McDonald | GIS Data Coordinator | Angus Council, People, IT | Angus
House, Orchardbank Business Park, Sylvie Way, Forfar DD8 1AT | t: 01307
476419
This message is strictly confidential. If you have received this in error,
please inform the sender and remove it from your system. If received in
error you may not copy, print, forward or use it or any attachment in any
way. This message is not capable of creating a legal contract or a binding
representation and does not represent the views of Angus Council. Emails may
be monitored for security and network management reasons. Messages
containing inappropriate content may be intercepted. Angus Council does not
accept any liability for any harm that may be caused to the recipient system
or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180321/41605933/attachment.html>
