[postgis-users] Replacement for Oracle's TRANSFORM_LAYER procedure?
Bryan Hall
bryan.hall at chk.com
Wed May 9 08:01:41 PDT 2018
Classification: DCL-Internal
I’m starting to look at the stored procedures we will need to move to PostGIS from Oracle, and I don’t see anything like SDO_CS.TRANSFORM_LAYER in the manual for a built-in procedure. Yes of course there is ST_Transform, but that does it in place, or in-line. However, here we are making a new table in a different SRID and it would be rather nice not to hard-code the columns in the source table (or MV in this case), or copy the table as a whole and then do a clunky in-place update. Yes, I’d rather just add another geography column and make it a computed column – but stupid ESRI software has to read this data. 😊
Is there a good site to look for “convenience functions” like this for PostGIS? I’d rather not spend time “re-inventing the wheel” if I don’t have to.
Thanks, Bryan
This email (and attachments if any) is intended only for the use of the individual or entity to which it is addressed, and may contain information that is confidential or privileged and exempt from disclosure under applicable law. If the reader of this email is not the intended recipient, or the employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify the sender immediately by return email and destroy all copies of the email (and attachments if any).
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180509/15ce7b69/attachment.html>
