[postgis-users] [EXTERNAL] Re: Replacement for Oracle's TRANSFORM_LAYER procedure?
Bryan Hall
bryan.hall at chk.com
Thu May 10 05:03:29 PDT 2018
Darafei,
Yes, I understand what needs to be done. I had thought by now someone would have created some Oracle -> PostGIS work-alike libraries for items like this. Since this does not seem to be the case, I will write a convenience procedure to do it then and share it back out when complete.
Bryan
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Darafei "Kom?pa" Praliaskouski
Sent: Thursday, May 10, 2018 03:14
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] [EXTERNAL] Re: Replacement for Oracle's TRANSFORM_LAYER procedure?
A simplest nobrainer way:
create table new_table as (select * from old_table);
update new_table set geom = ST_Transform(geom, new_srid);
create index on new_table using gist(geom);
A more optimized one will be to inline the list all the columns in create table as:
create table new_table as (select column1, column2, ... , ST_Transform(geom, new_srid) as geom from old_table);
ср, 9 мая 2018 г. в 19:01, Bryan Hall <bryan.hall at chk.com<mailto:bryan.hall at chk.com>>:
Classification: DCL-Internal
Alexandre,
SDO_CS.TRANSFORM_LAYER clones the input table (or MV) to a new table, transforming the geometry column specified to the new SRID. For example:
SDO_CS.TRANSFORM_LAYER('LSE_DETAIL_ACTIVE','SHAPE','LDA_NAD27',4267);
This clones the LSE_DETAIL_ACTIVE table to one called LDA_NAD27, while transforming the SHAPE column to SRID 4267.
Bryan
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org<mailto:postgis-users-bounces at lists.osgeo.org>] On Behalf Of Alexandre Neto
Sent: Wednesday, May 09, 2018 10:46
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>>
Subject: [EXTERNAL] Re: [postgis-users] Replacement for Oracle's TRANSFORM_LAYER procedure?
You may need to explain what SDO_CS.TRANSFORM does.
To transform a table's geometry SRID I use the following:
ALTER TABLE <table_name> ALTER COLUMN <geom_column_name> TYPE geometry(<geometry_type>, <target_CRS>) USING ST_Transform(<geom_column_name>, <target_CRS>);
Bryan Hall <bryan.hall at chk.com<mailto:bryan.hall at chk.com>> escreveu no dia quarta, 9/05/2018 às 16:02:
I’m starting to look at the stored procedures we will need to move to PostGIS from Oracle, and I don’t see anything like SDO_CS.TRANSFORM_LAYER in the manual for a built-in procedure. Yes of course there is ST_Transform, but that does it in place, or in-line. However, here we are making a new table in a different SRID and it would be rather nice not to hard-code the columns in the source table (or MV in this case), or copy the table as a whole and then do a clunky in-place update. Yes, I’d rather just add another geography column and make it a computed column – but stupid ESRI software has to read this data. 😊
Is there a good site to look for “convenience functions” like this for PostGIS? I’d rather not spend time “re-inventing the wheel” if I don’t have to.
Thanks, Bryan
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users<https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.osgeo.org_mailman_listinfo_postgis-2Dusers&d=DwMFaQ&c=M7nMI6M-Uv3ihEfN-QJ3_sQdVexoO64eU4Ftr4lnVk0&r=-89XSUoV_kZKlHf89FQGuyqPyUjA53juyA-7r7GoZVA&m=VJx8UZRUZFpdr1ed5RsLe4AkoOQd6583QJe3ijFDTKI&s=GRSBAMi-gfM8IbXGcO8-kpVRYTqVoNl5C2bc0Ns2VYc&e=>
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com<https://urldefense.proofpoint.com/v2/url?u=http-3A__sigsemgrilhetas.wordpress.com&d=DwMFaQ&c=M7nMI6M-Uv3ihEfN-QJ3_sQdVexoO64eU4Ftr4lnVk0&r=-89XSUoV_kZKlHf89FQGuyqPyUjA53juyA-7r7GoZVA&m=VJx8UZRUZFpdr1ed5RsLe4AkoOQd6583QJe3ijFDTKI&s=Qg237IQgPug6UcNiYy0IK1RXInkSfDg09SweWtZAo40&e=>
http://gisunchained.wordpress.com<https://urldefense.proofpoint.com/v2/url?u=http-3A__gisunchained.wordpress.com&d=DwMFaQ&c=M7nMI6M-Uv3ihEfN-QJ3_sQdVexoO64eU4Ftr4lnVk0&r=-89XSUoV_kZKlHf89FQGuyqPyUjA53juyA-7r7GoZVA&m=VJx8UZRUZFpdr1ed5RsLe4AkoOQd6583QJe3ijFDTKI&s=sjDQ5sUi7TYoGrSSYxZoCjL3CfUebZ_wTdr9koJG_Ds&e=>
This email (and attachments if any) is intended only for the use of the individual or entity to which it is addressed, and may contain information that is confidential or privileged and exempt from disclosure under applicable law. If the reader of this email is not the intended recipient, or the employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify the sender immediately by return email and destroy all copies of the email (and attachments if any).
https://lists.osgeo.org/mailman/listinfo/postgis-users<https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.osgeo.org_mailman_listinfo_postgis-2Dusers&d=DwMFaQ&c=M7nMI6M-Uv3ihEfN-QJ3_sQdVexoO64eU4Ftr4lnVk0&r=-89XSUoV_kZKlHf89FQGuyqPyUjA53juyA-7r7GoZVA&m=uxr79OxAhdg1JVOmirwWxS6VIUR1jOgeaftefCycuG4&s=4oFKXIMgLkQH4ifyqHvcSGnrDeKS3b5-ENbGj_8POhw&e=>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180510/0c401831/attachment.html>
