[postgis-users] [Partially solved] Re: Upgrade from Postgis 1.5.1-5 to 2.3.1
Darafei "Komяpa" Praliaskouski me at komzpa.net
Sat Nov 10 10:11:03 PST 2018
Привет,
That chapter is part of PostGIS documentation which is part of PostGIS
itself. You can edit here:
https://github.com/postgis/postgis/blob/svn-trunk/doc/installation.xml
(just push [Edit], do your changes and [Save] -> [New pull request]).
Please also mention what is IGN and why it produces invalid SRIDs, and what
do you lose by removing them. :)
пт, 9 нояб. 2018 г. в 19:24, Michel Philippenko <michel.ing93 at gmail.com>:
> Hello,
> I have managed to avoid errors in relation with spatial_ref_sys_srid_check
> and I asked the administrators of the website postgis.net to add some
> information in this page :
> https://postgis.net/docs/postgis_installation.html#hard_upgrade
> in the chapter :
> "Some custom records of spatial_ref_sys in dump file have an invalid SRID
> value"
> Information to insert :
> "Typically, if you use the french system IGN, you will have problems with
> SRID values out of range. You need first to throw out completely the IGN
> from the sql which is resulting from postgis_restore.pl. So, first run :
> perl utils/postgis_restore.pl "/somepath/olddb.backup" > oldbb.sql
> then
> grep -v IGNF olddb.sql > olddb-without-IGN.sql
> then create your newdb, activate the required Postgis extensions, and
> insert properly the french system IGN with this script :
> https://raw.githubusercontent.com/Remi-C/IGN_spatial_ref_for_PostGIS/master/Put_IGN_SRS_into_Postgis.sql
> then, to finish, run :
> psql -h localhost -p 5432 -U postgres -d newdb -f olddb-without-IGN.sql
> 2> errors.txt
> Thank you very much for you attention,
> With best regards,
> Mikhael Philippenko.
> Le jeu. 8 nov. 2018 à 14:55, Michel Philippenko <michel.ing93 at gmail.com>
> a écrit :
>> Hello,
>> I'm new with Postgis.
>> I'm upgrading a database from Postgis 1.5.1-5 to 2.3.1 following the
>> instructions given on this web page :
>> https://postgis.net/docs/postgis_installation.html#hard_upgrade.
>> The errors below are displayed when importing my dump. Will my DB work
>> well ? Should I fight more to have no errors at all ?
>> Thank you for your help and your attention.
>> With best regards,
>> Mikhael.
>> ERREUR:  la famille d'opérateur « btree_geography_ops » existe déjà pour
>> la méthode d'accès « btree »
>> ERREUR:  la famille d'opérateur « btree_geometry_ops » existe déjà pour
>> ERREUR:  la famille d'opérateur « gist_geography_ops » existe déjà pour
>> la méthode d'accès « gist »
>> ERREUR:  la contrainte de vérification « spatial_ref_sys_srid_check » est
>> rompue par une ligne
>> ERREUR:  n'a pas pu créer l'index unique « spatial_ref_sys_pkey »
>> DÉTAIL : La clé (srid)=(999954) est dupliquée.
>> My translation in English :
>> ERROR:  the operator family « btree_geography_ops » already exists for
>> the access method « btree »
>> ERROR:  the operator family « btree_geometry_ops »already exists for the
>> ERROR:  the operator family « gist_geography_ops » already exists for the
>> access method « gist »
>> ERROR:  the constraint check « spatial_ref_sys_srid_check » is broken
>> for one line
>> ERROR:  could not create the uniq index « spatial_ref_sys_pkey »
>> DETAIL : The key (srid)=(999954) is duplicated.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20181110/d86e61b6/attachment.html>
