[postgis-users] PostGIS upgrade 2.2.1 -> 2.5.0 Database Import Errors
Sandro Santilli
strk at kbt.io
Mon Oct 29 08:09:17 PDT 2018
On Mon, Oct 29, 2018 at 08:45:12AM -0600, Patrick Stout wrote:
> I'm moving a database from PostGIS 2.2.1 to 2.5.0 (PG 9.6). I pg_dumped the
> old database and am using pg_restore to import it.
> Everything appears to go fine but I'm getting these two errors. Is this
> something I need to worry about or can just ignore them?
You can probably ignore failure to restore "accum" and "makeline",
unless you need those two deprecated signatures.
Are you aware of postgis_restore.pl ? It's supposed to reduce
the noise when restoring a dump of a PostGIS enabled database.
--strk;
