[postgis-users] PostGIS upgrade 2.2.1 -> 2.5.0 Database Import Errors
Patrick Stout pstout at prevagroup.com
Mon Oct 29 08:20:29 PDT 2018
I tried postgis_restore.pl but it failed with a bunch of errors (maybe I
ran it incorrectly...).
I'll try this again and see what happens.
Thanks for the info.
Patrick
On Mon, Oct 29, 2018 at 9:17 AM Sandro Santilli <strk at kbt.io> wrote:
> On Mon, Oct 29, 2018 at 08:45:12AM -0600, Patrick Stout wrote:
> > I'm moving a database from PostGIS 2.2.1 to 2.5.0 (PG 9.6). I pg_dumped
> the
> > old database and am using pg_restore to import it.
> > Everything appears to go fine but I'm getting these two errors. Is this
> > something I need to worry about or can just ignore them?
> You can probably ignore failure to restore "accum"  and "makeline",
> unless you need those two deprecated signatures.
> Are you aware of postgis_restore.pl ? It's supposed to reduce
> the noise when restoring a dump of a PostGIS enabled database.
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20181029/04605c6e/attachment.html>
