[postgis-users] postgis-users Digest, Vol 199, Issue 4
Aaron Edwards
aedwards at b3insight.com
Thu Sep 13 08:05:47 PDT 2018
Thanks, Regina. That was actually it. It was a bug in a Windows update, that Microsoft patched a week later, but we didn't know about it. We installed the patch and port 80 is now available again.
Aaron
-----Original Message-----
From: postgis-users <postgis-users-bounces at lists.osgeo.org> On Behalf Of postgis-users-request at lists.osgeo.org
Sent: Tuesday, September 11, 2018 1:00 PM
To: postgis-users at lists.osgeo.org
Subject: postgis-users Digest, Vol 199, Issue 4
Send postgis-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.osgeo.org/mailman/listinfo/postgis-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
postgis-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of postgis-users digest..."
Today's Topics:
1. GEOS 3.7.0 is released (Regina Obe)
2. Address Already In Use: bind (Aaron Edwards)
3. Re: [EXTERNAL] Address Already In Use: bind (Thomas, Cord)
4. Re: Address Already In Use: bind (Regina Obe)
Message: 1
Date: Tue, 11 Sep 2018 01:21:38 -0400
To: "'GEOS Development List'" <geos-devel at lists.osgeo.org>
Cc: "'PostGIS Development Discussion'"
<postgis-devel at lists.osgeo.org>, "'PostGIS Users Discussion'"
<postgis-users at lists.osgeo.org>, <discuss at lists.osgeo.org>
Subject: [postgis-users] GEOS 3.7.0 is released
Message-ID: <001901d4498f$5140cfe0$f3c26fa0$@pcorp.us>
Content-Type: text/plain; charset="us-ascii"
The GEOS development team is proud to finally release GEOS 3.7.0.
After many years of soul searching, we finally got out a release.
Note this is the first release to require a C++11 compiler to compile.
Source code can be downloaded from:
https://download.osgeo.org/geos/geos-3.7.0.tar.bz2
3.7.0 changes
2018-09-10
- New things:
- CAPI: GEOSDistanceIndexed (#795, Dan Baston)
- CAPI: GEOSCoordSeq_isCCW (#870, Dan Baston)
- CAPI: GEOSGeom_getXMin, GEOSGeom_getXMax,
GEOSGeom_getYMin, GEOSGeom_getYMax (#871, Dan Baston)
- CAPI: GEOSFrechetDistance (#797, Shinichi SUGIYAMA)
- CAPI: GEOSReverse (#872, Dan Baston)
- CAPI: GEOSGeomGetZ (#581, J Smith)
- Improvements
- Interruptible snap operation (Paul Ramsey)
- Numerous packaging, doc, and build changes
(Debian group: Bas Couwenberg, Francesco Paolo Lovergine)
(NetBSD: Greg Troxel)
- Allow static library with C API for CMake builds (#878, Dakota Hawkins)
- C++ API changes:
- Require defining USE_UNSTABLE_GEOS_CPP_API for use without
warnings.
- Make C++11 required (Mateusz Loskot)
- Use C++11 unique_ptr, nullptr, and override constructs
(Mateusz Loskot)
- C++11 standard delete on noncopyable
(#851, Vicky Vergara)
- Fix CommonBits::getBit to correctly handle i >= 32
(#834, Kurt Schwehr)
Thanks,
GEOS Development Team
Message: 2
Date: Tue, 11 Sep 2018 15:29:31 +0000
To: "postgis-users at lists.osgeo.org" <postgis-users at lists.osgeo.org>
Subject: [postgis-users] Address Already In Use: bind
Message-ID:
<DM5PR1301MB2058193A257D9879A9AA1E9491040 at DM5PR1301MB2058.namprd13.prod.outlook.com>
Content-Type: text/plain; charset="utf-8"
We're running Geoserver 2.11.2 on Windows, under Jetty.
We configured the service to listen on Port 80, instead of 8080.
Now we can't restart the service: we get the error: Address Already In Use: bind. There is nothing else listening on port 80.
We can, however, restart the server, and then the Geoserver service starts up correctly. But if we just restart the Geoserver service, it won't come back up.
Thanks.
Aaron
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180911/3af6283d/attachment-0001.html>
Message: 3
Date: Tue, 11 Sep 2018 15:37:51 +0000
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] [EXTERNAL] Address Already In Use: bind
Message-ID: <F13DACF9-F551-4626-9C26-2199F91042E7 at rand.org>
Wild guess about port 80 reporting in use- depending on Windows version, there may be a patch installed that causes this issue – summarized nicely here
https://kb.tableau.com/articles/Issue/kb4338818-windows-update-causing-tableau-server-to-become-unstable
See table at bottom for versions of patches causing problems and where resolved.
Cord
From: postgis-users <postgis-users-bounces at lists.osgeo.org> on behalf of Aaron Edwards <aedwards at b3insight.com>
Reply-To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Date: Tuesday, September 11, 2018 at 8:30 AM
Subject: [EXTERNAL] [postgis-users] Address Already In Use: bind
We’re running Geoserver 2.11.2 on Windows, under Jetty.
Now we can’t restart the service: we get the error: Address Already In Use: bind. There is nothing else listening on port 80.
We can, however, restart the server, and then the Geoserver service starts up correctly. But if we just restart the Geoserver service, it won’t come back up.
Thanks.
Aaron
__________________________________________________________________________
This email message is for the sole use of the intended recipient(s) and may contain information that is sensitive, proprietary, and/or privileged.
Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180911/ef52ad5d/attachment-0001.html>
Message: 4
Date: Tue, 11 Sep 2018 13:19:48 -0400
To: "'PostGIS Users Discussion'" <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Address Already In Use: bind
Message-ID: <002f01d449f3$a5396670$efac3350$@pcorp.us>
Found this on stack that might be your problem.
https://gis.stackexchange.com/questions/200568/why-cant-i-run-the-opengeosui
te-on-port-80
I know Tomcat isn't Jetty but might be a similar thing, that you need admin rights to run on lower ports.
What account is your geoserver service running under? Maybe switch it to higher level account.
Hope that helps,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Aaron Edwards
Sent: Tuesday, September 11, 2018 11:30 AM
Thanks.
Aaron
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180911/93135855/attachment-0001.html>
Subject: Digest Footer
End of postgis-users Digest, Vol 199, Issue 4
