[postgis-users] 2.4.5 Released
Paul Ramsey
pramsey at cleverelephant.ca
Wed Sep 12 10:04:43 PDT 2018
The PostGIS development team is pleased to provide bug fix release 2.4.5
for the 2.4 stable branch.
- #4031, Survive to big MaxError tolerances passed to ST_CurveToLine
(Sandro Santilli)
- #4058, Fix infinite loop in linearization of a big radius small arc
(Sandro Santilli)
- #4071, ST_ClusterKMeans crash on NULL/EMPTY fixed (Darafei
Praliaskouski)
- #4079, ensure St_AsMVTGeom outputs CW oriented polygons (Paul Ramsey)
- #4070, use standard interruption error code on GEOS interruptions
(Paul Ramsey)
- #3980, delay freeing input until processing complete (lucasvr)
- #4090, PG 11 support (Paul Ramsey, Raúl Marín)
- #4077, Serialization failure for particular empty geometry cases (Paul
Ramsey)
- #3997, fix bug in lwgeom_median and avoid division by zero (Raúl Marín)
- #4093, Inconsistent results from qsort callback (yugr)
- #4081, Geography DWithin() issues for certain cases (Paul Ramsey)
- #4105, Parallel build of tarball (Bas Couwenberg)
https://trac.osgeo.org/postgis/query?status=closed&resolution=fixed&milestone=PostGIS+2.4.5&col=id&col=summary&col=milestone&col=status&col=type&col=priority&col=component&order=priority
As usual, source downloads are available via http://postgis.net/source/
Your faithful,
PostGIS Development Crew
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180912/092baf7d/attachment.html>
