[postgis-users] [EXTERNAL] Address Already In Use: bind
Thomas, Cord
cthomas at rand.org
Tue Sep 11 08:37:51 PDT 2018
Wild guess about port 80 reporting in use- depending on Windows version, there may be a patch installed that causes this issue – summarized nicely here
https://kb.tableau.com/articles/Issue/kb4338818-windows-update-causing-tableau-server-to-become-unstable
See table at bottom for versions of patches causing problems and where resolved.
Cord
From: postgis-users <postgis-users-bounces at lists.osgeo.org> on behalf of Aaron Edwards <aedwards at b3insight.com>
Reply-To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Date: Tuesday, September 11, 2018 at 8:30 AM
To: "postgis-users at lists.osgeo.org" <postgis-users at lists.osgeo.org>
Subject: [EXTERNAL] [postgis-users] Address Already In Use: bind
We’re running Geoserver 2.11.2 on Windows, under Jetty.
We configured the service to listen on Port 80, instead of 8080.
Now we can’t restart the service: we get the error: Address Already In Use: bind. There is nothing else listening on port 80.
We can, however, restart the server, and then the Geoserver service starts up correctly. But if we just restart the Geoserver service, it won’t come back up.
Thanks.
Aaron
__________________________________________________________________________
This email message is for the sole use of the intended recipient(s) and
may contain information that is sensitive, proprietary, and/or privileged.
Any unauthorized review, use, disclosure or distribution is prohibited. If
you are not the intended recipient, please contact the sender by reply
email and destroy all copies of the original message.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180911/ef52ad5d/attachment.html>
