[postgis-users] Address Already In Use: bind
Regina Obe
lr at pcorp.us
Tue Sep 11 10:19:48 PDT 2018
Found this on stack that might be your problem.
https://gis.stackexchange.com/questions/200568/why-cant-i-run-the-opengeosui
te-on-port-80
I know Tomcat isn't Jetty but might be a similar thing, that you need admin
rights to run on lower ports.
What account is your geoserver service running under? Maybe switch it to
higher level account.
Hope that helps,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Aaron Edwards
Sent: Tuesday, September 11, 2018 11:30 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Address Already In Use: bind
We're running Geoserver 2.11.2 on Windows, under Jetty.
We configured the service to listen on Port 80, instead of 8080.
Now we can't restart the service: we get the error: Address Already In Use:
bind. There is nothing else listening on port 80.
We can, however, restart the server, and then the Geoserver service starts
up correctly. But if we just restart the Geoserver service, it won't come
back up.
Thanks.
Aaron
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180911/93135855/attachment.html>
