[postgis-users] Error on PostGIS
Pradeep Kanth G
pgundala at avineonindia.com
Fri Aug 2 02:34:34 PDT 2019
Trying on below versions..
postgis-2.2.1
geos-3.3.5
gdal-1.9.1
Installed proj-4.8.0 , proj-4.9.1 and proj-5.2.0 but no luck.
Regards
Pradeep Kanth
From: postgis-users <postgis-users-bounces at lists.osgeo.org> On Behalf Of Darafei "Kom?pa" Praliaskouski
Sent: Friday, August 2, 2019 2:40 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Error on PostGIS
Hello,
what are the versions of proj and postgis that you are using?
On Fri, Aug 2, 2019 at 12:03 PM Pradeep Kanth G <pgundala at avineonindia.com <mailto:pgundala at avineonindia.com> > wrote:
Dear All,
While installing the PostGIS, getting the below error.
./configure --with-pgconfig=/home/postgres/pgxl/bin/pg_config
Error:
configure: error: could not find proj_api.h - you may need to specify the directory of a PROJ.4 installation using --with-projdir
make: *** [GNUmakefile] Error 1
Verified PROJ.4 already installed my machine . Kindly let us know go to overcome this issue.
Regards
Pradeep Kanth
Disclaimer | The information contained in this electronic message (including any attachments) is intended for the exclusive use of the addressee(s) and may contain confidential or privileged information.If you have received this in error, please notify the sender immediately and delete the material from your machine. Any action including review, retransmission, dissemination of this email or the attachments present along with the email by persons or entities other than the intended recipient is prohibited.
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190802/0a9852a1/attachment.html>
