[postgis-users] Error on PostGIS
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Fri Aug 2 02:35:55 PDT 2019
Hello,
PostGIS 2.2 is End of Life. Current release is 2.5.2.
GEOS 3.3 is End of Life. Current release is 3.7.2.
Please consult this matrix when choosing the best versions combinations:
https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
On Fri, Aug 2, 2019 at 12:33 PM Pradeep Kanth G <pgundala at avineonindia.com>
wrote:
> Hi,
> Trying on below versions..
> postgis-2.2.1
> geos-3.3.5
> gdal-1.9.1
> Installed proj-4.8.0 , proj-4.9.1 and proj-5.2.0 but no luck.
> Regards
> Pradeep Kanth
> *From:* postgis-users <postgis-users-bounces at lists.osgeo.org> *On Behalf
> Of *Darafei "Kom?pa" Praliaskouski
> *Sent:* Friday, August 2, 2019 2:40 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] Error on PostGIS
> Hello,
> what are the versions of proj and postgis that you are using?
> On Fri, Aug 2, 2019 at 12:03 PM Pradeep Kanth G <pgundala at avineonindia.com>
> wrote:
> Dear All,
> While installing the PostGIS, getting the below error.
> ./configure --with-pgconfig=/home/postgres/pgxl/bin/pg_config
> Error:
> configure: error: could not find proj_api.h - you may need to specify the
> directory of a PROJ.4 installation using --with-projdir
> make: *** [GNUmakefile] Error 1
> Verified PROJ.4 already installed my machine . Kindly let us know go to
> overcome this issue.
> Regards
> Pradeep Kanth
> *Disclaimer *| The information contained in this electronic message
> (including any attachments) is intended for the exclusive use of the
> addressee(s) and may contain confidential or privileged information.If you
> have received this in error, please notify the sender immediately and
> delete the material from your machine. Any action including review,
> retransmission, dissemination of this email or the attachments present
> along with the email by persons or entities other than the intended
> recipient is prohibited.
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
> Darafei Praliaskouski
> Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190802/cd12ae70/attachment.html>
