[postgis-users] Error on PostGIS
Darafei "Komяpa" Praliaskouski me at komzpa.net
Fri Aug 2 02:57:38 PDT 2019
Can you check that development headers of proj are actually available,
looking for proj_api.h in your file system?
On Fri, Aug 2, 2019 at 12:55 PM Pradeep Kanth G <pgundala at avineonindia.com>
wrote:
> Hi,
> Installed latest(PostGIS2.5.2 & GEOS 3.7.2) version, but getting the same
> error.
> configure: error: could not find proj_api.h - you may need to specify the
> directory of a PROJ.4 installation using --with-projdir
> Regards
> Pradeep Kanth
> *From:* postgis-users <postgis-users-bounces at lists.osgeo.org> *On Behalf
> Of *Darafei "Kom?pa" Praliaskouski
> *Sent:* Friday, August 2, 2019 3:06 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] Error on PostGIS
> Hello,
> PostGIS 2.2 is End of Life. Current release is 2.5.2.
> GEOS 3.3 is End of Life. Current release is 3.7.2.
> Please consult this matrix when choosing the best versions combinations:
> https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
> On Fri, Aug 2, 2019 at 12:33 PM Pradeep Kanth G <pgundala at avineonindia.com>
> wrote:
> Hi,
> Trying on below versions..
> postgis-2.2.1
> geos-3.3.5
> gdal-1.9.1
> Installed proj-4.8.0 , proj-4.9.1 and proj-5.2.0 but no luck.
> Regards
> Pradeep Kanth
> *Sent:* Friday, August 2, 2019 2:40 PM
> Hello,
> what are the versions of proj and postgis that you are using?
> On Fri, Aug 2, 2019 at 12:03 PM Pradeep Kanth G <pgundala at avineonindia.com>
> wrote:
> Dear All,
> While installing the PostGIS, getting the below error.
> ./configure --with-pgconfig=/home/postgres/pgxl/bin/pg_config
> Error:
> make: *** [GNUmakefile] Error 1
> Verified PROJ.4 already installed my machine . Kindly let us know go to
> overcome this issue.
> Regards
> Pradeep Kanth
> *Disclaimer *| The information contained in this electronic message
> (including any attachments) is intended for the exclusive use of the
> addressee(s) and may contain confidential or privileged information.If you
> have received this in error, please notify the sender immediately and
> delete the material from your machine. Any  action including review,
> retransmission, dissemination of this email or the attachments present
> along with the email by persons or entities other than the intended
> recipient is prohibited.
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
> Darafei Praliaskouski
> Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190802/a87c7e5b/attachment.html>
