[postgis-users] ST_ConcaveHull performance issue
Trevor Wiens tsw.web at gmail.com
Fri Aug 2 10:16:01 PDT 2019
Thanks for your reply. It was mix of points, lines and polygons, but when I
broke it down it was the lines causing the problem.
I tried commenting out the line in the ST_ConcaveHull function you
suggested but that doesn't make a difference. I suspect there is some
underlying library that has changed.
I will open a ticket as you suggest.
Thanks
TSW
On Thu, Aug 1, 2019 at 11:55 PM Darafei "Komяpa" Praliaskouski <
me at komzpa.net> wrote:
> Hi,
> There were changes ST_ConcaveHull that fixed robustness of it in 2.2 ->
> 2.5 chain.
> To point where the penalty comes from, try to run a query and on a side
> console server-side run `sudo perf top`. Function names will get you a
> rough idea where the execution process lives now.
> To further debug, go to blame view in github and try updating
> st_concavehull (it's in SQL) change by change. Most recent adds an union
> here, try commenting it out and hot reloading on your db.
> https://github.com/postgis/postgis/blame/svn-trunk/postgis/postgis.sql.in#L6155
> Can you share the data and ticket this on http://trac.osgeo.org/postgis/?
> What is the data structurally? Are these 6000 objects points, or polygons?
> On Fri, Aug 2, 2019 at 3:43 AM Trevor Wiens <tsw.web at gmail.com> wrote:
>> I am having difficulty determining why I'm seeing significant differences
>> in performance between two database configurations with the same data.
>> One one machine (centos) I have the following software:
>> geos 3.5.0
>> sfcgal 1.3.1
>> cgal 4.7.1
>> postgis 2.2
>> postgresql 9.4
>> On a second machine (debian 10) I have the following:
>> geos 3.7.1
>> sfcgal 1.3.6
>> cgal 4.13
>> postgis 2.5.2
>> postgresql 9.6
>> In terms of hardware there is no significant difference, if anything the
>> second machine is more capable, but that is not reflected in my performance
>> results.
>> On the first machine when I run a ST_ConcaveHull with about 6000
>> features, I get result a second or two. On the second machine, it won't
>> finish within 30 minutes. Both are using geos as the postgis.backend. I
>> don't understand why the one is so much faster than the other with the
>> identical data and query.
>> Any suggestions as to what to what the cause may be or how I might
>> diagnose the cause?
>> Any clues would be greatly appreciated.
>> TSW
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
> Darafei Praliaskouski
> Support me: http://patreon.com/komzpa
Trevor Wiens
Apropos Information Systems
aproposinfosystems.com
Calgary, Alberta
Ph. 403-973-5901
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190802/aa91c3ce/attachment.html>
