[postgis-users] ArcGIS desktop accessing and reading from PostGIS
Shaozhong SHI
shishaozhong at gmail.com
Wed Aug 21 00:18:25 PDT 2019
Hi, Bob,
Can you point me to excellent technical documentation on what you
mentioned, so that I can double-check.
My colleagues have made it working, but there are some issues. For
instance, not all ArcGIS desktops can access and retrieve data.
Looking forward to have more insight into this matter.
Regards,
Shao
On Tue, 20 Aug 2019 at 17:08, Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
> All,
> One biggie, is that the ESRI side does not like connecting to the
> “postgres” named database, claiming it’s a System database (whatever that
> means). This is not readily available as a limitation either when looking
> for reasons why it won’t connect. We’ve been using the “postgres” database
> name for years (a decade now??) with no ill effects from other
> applications/ connections. I sort of understand this from the commercial
> side having worked with other databases like Oracle and MSSQL, but still,
> there should be a way to side step this with a setting somewhere.
> I looked high and low for a way to alias the “postgres” database name
> inside of Postgres, but didn’t find anything very easy to implement or
> maintain very easily. I did think about setting up another dataabase and
> using Views to the postgres database, but that seemed like a bad idea for
> some reason, along with being somewhat hard to maintain, but upon
> reflection I keep coming back to the idea.
> All non “postgres” named connections seem to work fine so far. Haven’t
> implemented anything yet that is really heavy duty as far as loading
> though, so who knows.
> Anyway, just my 2cents.
> bobb
> On Aug 20, 2019, at 10:12 AM, Shaozhong SHI <shishaozhong at gmail.com>
> wrote:
> *Think Before You Click: *This email originated *outside *our
> organization.
> How to ensure that all versions of ArcGIS desktop applications can access
> and read from server-based PostGIS/PostgreSQL?
> Regards,
> Shao
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190821/c577c28f/attachment.html>
