[postgis-users] PostgreSQL 12 and PostGIS
Bo Guo bo.guo at gisticinc.com
Sun Dec 22 19:36:12 PST 2019
Thanks, Regina!  I am running PostgeSQL 12 now!
However, when I ran *SELECT*PostGIS_Extensions_Upgrade(); the second
time, I have the following msg.
NOTICE: Extension postgis_sfcgal is not available or not packagable for
some reason
NOTICE: Packaging extension postgis_raster
WARNING: 'postgis.gdal_datapath' is already set and cannot be changed
until you reconnect
WARNING: 'postgis.gdal_enabled_drivers' is already set and cannot be
changed until you reconnect
WARNING: 'postgis.enable_outdb_rasters' is already set and cannot be
ERROR: function public.st_srid(geometry) does not exist
LINE 1: ..._makeemptyraster($1, $2, $3, $4, $5, -($5), 0, 0,
public.ST_... ^
HINT: No function matches the given name and argument types. You might
need to add explicit type casts.
QUERY: SELECT public.ST_makeemptyraster($1, $2, $3, $4, $5, -($5), 0, 0,
public.ST_SRID('POINT(0 0)'::geometry))
CONTEXT: SQL statement "CREATE EXTENSION postgis_raster FROM unpackaged"
PL/pgSQL function postgis_extensions_upgrade() line 48 at EXECUTE
SQL state: 42883
On 12/22/19 8:09 PM, Regina Obe wrote:
> NO NO  don’t do that.  Those set of libraries aren’t compatible with
> each other.
> The PostGIS 3.0 and 2.5 from 12 are compatible with each other however.
> So
> What you want to do is
> cp /usr/lib/postgresql/12/lib/postgis-3.so
> /usr/lib/postgresql/12/lib/postgis-2.5.so
> cp /usr/lib/postgresql/12/lib/postgis_raster-3.so
> /usr/lib/postgresql/12/lib/rtpostgis-2.5.so
> cp /usr/lib/postgresql/12/lib/postgis_topology-3.so
> /usr/lib/postgresql/12/lib/postgis_topology-2.5.so
> Then after the upgrade in each of your databases run:
> And then run it again to rebundle the raster into it’s own extension
> Then if you don’t need raster, you can
> DROP EXTENSION postgis_raster;
> Once you are done upgrading your databases, you can delete thr
> *-2.5.so files you created in the 12 cluster.
> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> *On Behalf Of *Bo Guo
> *Sent:* Sunday, December 22, 2019 10:01 PM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Re: [postgis-users] PostgreSQL 12 and PostGIS
> Thanks, Regina,
> I copied the three 2.5 lib files from/usr/lib/postgresql/11/lib to
> /usr/lib/postgresql/12/lib:
> guob at yuma:/usr/lib/postgresql/12/lib$ ls -al *post*
> -rw-r--r-- 1 root root  456832 Dec 22 19:49 postgis-2.5.so
> -rw-r--r-- 1 root root 1351536 Oct 28 21:24 postgis-3.so
> -rw-r--r-- 1 root root  847424 Oct 28 21:24 postgis_raster-3.so
> -rw-r--r-- 1 root root  364224 Dec 22 19:49 postgis_topology-2.5.so
> -rw-r--r-- 1 root root  569152 Oct 28 21:24 postgis_topology-3.so
> -rw-r--r-- 1 root root  100264 Nov 12 03:33 postgres_fdw.so
> -rw-r--r-- 1 root root  399136 Dec 22 19:50 rtpostgis-2.5.so
> However, the three lib files are still in the loadable_libraries.txt file.
> Bo
> On 12/22/19 7:42 PM, Regina Obe wrote:
>     Bo,
>     Do you have the postgis-2.5.so, rtpostgis-2.5.so, postgis_topology-2.5.so
>     files in
>     And
>     Those are the files it's complaining about.
>     From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
>     Of Bo Guo
>     Sent: Sunday, December 22, 2019 9:16 PM
>     To:postgis-users at lists.osgeo.org  <mailto:postgis-users at lists.osgeo.org>
>     Subject: Re: [postgis-users] PostgreSQL 12 and PostGIS
>     Regina and Stefan,
>     I might have run into a similar issues today as I was  trying to upgrade
>     PostgreSQL 11 w/ PostGIS 2.5 to PostgreSQL 12 w/ PostGIS 3.0.
>     The pg_upgradecluster command (sudo pg_upgradecluster -m upgrade 11 main)
>     failed its check for the following required libraries:
>          could not load library "$libdir/postgis-2.5": ERROR:  could not access
>     file "$libdir/postgis-2.5": No such file or directory
>          could not load library "$libdir/rtpostgis-2.5": ERROR:  could not access
>     file "$libdir/rtpostgis-2.5": No such file or directory
>          could not load library "$libdir/postgis_topology-2.5": ERROR:  could not
>     access file "$libdir/postgis_topology-2.5": No such file or directory
>     I have postgis-2.5 in the /usr/share/postgresql/11/contrib/ folder AND
>     /usr/share/postgresql/12/contrib/ folder.  I also have postgis-3.0 under
>     /usr/share/postgresql/12/contrib/.
>     Thanks for your help!
>     Bo
>     Gistic Research, Inc.
>     On 10/4/19 8:16 AM, Regina Obe wrote:
>     Stefan,
>     Which distro do you get your PostgreSQL 12 from.  I’m assuming
>     apt.postgresql.org
>     If so you should report on their mailing list, as that would be a packaging
>     bug,not a PostGIS one and no one on the PostGIS project is on the apt team.
>     https://www.postgresql.org/list/pgsql-pkg-debian/
>     Thanks,
>     Regina
>     Of Stefan Wolf
>     Sent: Friday, October 4, 2019 6:19 AM
>     Subject: [postgis-users] PostgreSQL 12 and PostGIS
>     Today I’ve installed the brand new PostgreSQL 12  on Ubuntu 18.04
>     “apt-get install postgis”  will install PostGIS 2.5.2, but the  PATH is
>     wrong:  /usr/share/postgresql/11/…
>     So CREATE EXTENSION postgis will fail.
>     Greetings from Berlin
>     -Stefan Wolf-
>     _______________________________________________
>     postgis-users mailing list
>     https://lists.osgeo.org/mailman/listinfo/postgis-users
> Regards,
> Bo Guo, PhD, PE
> President
> 2033 E Warner Rd Ste 105
> Tempe, AZ 85284
> www.gisticinc.com  <http://www.gisticinc.com>
> www.youtube.com/linearbench  <http://www.youtube.com/linearbench>
> Office: 480-656-9962
> Cell: 602-570-4697
Regards,
Bo Guo, PhD, PE
President
Tempe, AZ 85284
www.gisticinc.com
Cell: 602-570-4697
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191222/785ad792/attachment.html>
