[postgis-users] PostgreSQL 12 and PostGIS
Regina Obe lr at pcorp.us
Sun Dec 22 19:54:59 PST 2019
Okay I ran into that issue too.
It happens if you have PostGIS not installed in public.
I have the issue ticketed here – I thought I had fixed this already in 3.0.1 (not yet released yet), but evidentally I haven’t or forgot to close this ticket.
https://trac.osgeo.org/postgis/ticket/4555
The workaround is to do this:
CREATE EXTENSION postgis_raster FROM unpackaged VERSION "3.0.0" SCHEMA <schema where you installed postgis>;
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Bo Guo
Sent: Sunday, December 22, 2019 10:36 PM
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] PostgreSQL 12 and PostGIS
Thanks, Regina!  I am running PostgeSQL 12 now!
However, when I ran SELECT PostGIS_Extensions_Upgrade(); the second time, I have the following msg.
NOTICE: Extension postgis_sfcgal is not available or not packagable for some reason
NOTICE: Packaging extension postgis_raster
WARNING: 'postgis.gdal_datapath' is already set and cannot be changed until you reconnect
WARNING: 'postgis.gdal_enabled_drivers' is already set and cannot be changed until you reconnect
WARNING: 'postgis.enable_outdb_rasters' is already set and cannot be changed until you reconnect
ERROR: function public.st_srid(geometry) does not exist
LINE 1: ..._makeemptyraster($1, $2, $3, $4, $5, -($5), 0, 0, public.ST_... ^
HINT: No function matches the given name and argument types. You might need to add explicit type casts.
QUERY: SELECT public.ST_makeemptyraster($1, $2, $3, $4, $5, -($5), 0, 0, public.ST_SRID('POINT(0 0)'::geometry))
CONTEXT: SQL statement "CREATE EXTENSION postgis_raster FROM unpackaged"
PL/pgSQL function postgis_extensions_upgrade() line 48 at EXECUTE
SQL state: 42883
On 12/22/19 8:09 PM, Regina Obe wrote:
NO NO  don’t do that.  Those set of libraries aren’t compatible with each other.
The PostGIS 3.0 and 2.5 from 12 are compatible with each other however.
So
What you want to do is
cp /usr/lib/postgresql/12/lib/postgis-3.so /usr/lib/postgresql/12/lib/postgis-2.5.so
cp /usr/lib/postgresql/12/lib/postgis_raster-3.so /usr/lib/postgresql/12/lib/rtpostgis-2.5.so
cp /usr/lib/postgresql/12/lib/postgis_topology-3.so /usr/lib/postgresql/12/lib/postgis_topology-2.5.so
Then after the upgrade in each of your databases run:
And then run it again to rebundle the raster into it’s own extension
Then if you don’t need raster, you can
DROP EXTENSION postgis_raster;
Once you are done upgrading your databases, you can delete thr *-2.5.so files you created in the 12 cluster.
Sent: Sunday, December 22, 2019 10:01 PM
To: postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Thanks, Regina,
I copied the three 2.5 lib files from /usr/lib/postgresql/11/lib to /usr/lib/postgresql/12/lib:
guob at yuma:/usr/lib/postgresql/12/lib$ ls -al *post*
-rw-r--r-- 1 root root  456832 Dec 22 19:49 postgis-2.5.so
-rw-r--r-- 1 root root 1351536 Oct 28 21:24 postgis-3.so
-rw-r--r-- 1 root root  847424 Oct 28 21:24 postgis_raster-3.so
-rw-r--r-- 1 root root  364224 Dec 22 19:49 postgis_topology-2.5.so
-rw-r--r-- 1 root root  569152 Oct 28 21:24 postgis_topology-3.so
-rw-r--r-- 1 root root  100264 Nov 12 03:33 postgres_fdw.so
-rw-r--r-- 1 root root  399136 Dec 22 19:50 rtpostgis-2.5.so
However, the three lib files are still in the loadable_libraries.txt file.
Bo
On 12/22/19 7:42 PM, Regina Obe wrote:
Bo,
Do you have the postgis-2.5.so, rtpostgis-2.5.so, postgis_topology-2.5.so
files in
And
Those are the files it's complaining about.
Of Bo Guo
Sent: Sunday, December 22, 2019 9:16 PM
Regina and Stefan,
I might have run into a similar issues today as I was  trying to upgrade
PostgreSQL 11 w/ PostGIS 2.5 to PostgreSQL 12 w/ PostGIS 3.0.
The pg_upgradecluster command (sudo pg_upgradecluster -m upgrade 11 main)
failed its check for the following required libraries:
    could not load library "$libdir/postgis-2.5": ERROR:  could not access
file "$libdir/postgis-2.5": No such file or directory
    could not load library "$libdir/rtpostgis-2.5": ERROR:  could not access
file "$libdir/rtpostgis-2.5": No such file or directory
    could not load library "$libdir/postgis_topology-2.5": ERROR:  could not
access file "$libdir/postgis_topology-2.5": No such file or directory
I have postgis-2.5 in the /usr/share/postgresql/11/contrib/ folder AND
/usr/share/postgresql/12/contrib/ folder.  I also have postgis-3.0 under
/usr/share/postgresql/12/contrib/.
Thanks for your help!
Bo
Gistic Research, Inc.
On 10/4/19 8:16 AM, Regina Obe wrote:
Stefan,
Which distro do you get your PostgreSQL 12 from.  I’m assuming
apt.postgresql.org
If so you should report on their mailing list, as that would be a packaging
bug,not a PostGIS one and no one on the PostGIS project is on the apt team.
https://www.postgresql.org/list/pgsql-pkg-debian/
Thanks,
Regina
Of Stefan Wolf
Sent: Friday, October 4, 2019 6:19 AM
Subject: [postgis-users] PostgreSQL 12 and PostGIS
Today I’ve installed the brand new PostgreSQL 12  on Ubuntu 18.04
“apt-get install postgis”  will install PostGIS 2.5.2, but the  PATH is
wrong:  /usr/share/postgresql/11/…
So CREATE EXTENSION postgis will fail.
Greetings from Berlin
-Stefan Wolf-
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
Regards,
Bo Guo, PhD, PE
President
2033 E Warner Rd Ste 105
Tempe, AZ 85284
www.gisticinc.com <http://www.gisticinc.com>
www.youtube.com/linearbench <http://www.youtube.com/linearbench>
Office: 480-656-9962
Cell: 602-570-4697
Regards,
Bo Guo, PhD, PE
President
Tempe, AZ 85284
Cell: 602-570-4697
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191222/50d01e8a/attachment.html>
