[postgis-users] PostgreSQL 12 and PostGIS
Bo Guo
bo.guo at gisticinc.com
Sun Dec 22 20:11:44 PST 2019
Yeh! Thanks you, Regina!
On 12/22/19 8:54 PM, Regina Obe wrote:
> Okay I ran into that issue too.
> It happens if you have PostGIS not installed in public.
> I have the issue ticketed here – I thought I had fixed this already in
> 3.0.1 (not yet released yet), but evidentally I haven’t or forgot to
> close this ticket.
> https://trac.osgeo.org/postgis/ticket/4555
> The workaround is to do this:
> CREATE EXTENSION postgis_raster FROM unpackaged VERSION "3.0.0" SCHEMA
> <schema where you installed postgis>;
> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> *On Behalf Of *Bo Guo
> *Sent:* Sunday, December 22, 2019 10:36 PM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Re: [postgis-users] PostgreSQL 12 and PostGIS
> Thanks, Regina! I am running PostgeSQL 12 now!
> However, when I ran *SELECT*PostGIS_Extensions_Upgrade(); the second
> time, I have the following msg.
> NOTICE: Extension postgis_sfcgal is not available or not packagable
> for some reason
> NOTICE: Packaging extension postgis_raster
> WARNING: 'postgis.gdal_datapath' is already set and cannot be changed
> until you reconnect
> WARNING: 'postgis.gdal_enabled_drivers' is already set and cannot be
> changed until you reconnect
> WARNING: 'postgis.enable_outdb_rasters' is already set and cannot be
> ERROR: function public.st_srid(geometry) does not exist
> LINE 1: ..._makeemptyraster($1, $2, $3, $4, $5, -($5), 0, 0,
> public.ST_... ^
> HINT: No function matches the given name and argument types. You might
> need to add explicit type casts.
> QUERY: SELECT public.ST_makeemptyraster($1, $2, $3, $4, $5, -($5), 0,
> 0, public.ST_SRID('POINT(0 0)'::geometry))
> CONTEXT: SQL statement "CREATE EXTENSION postgis_raster FROM unpackaged"
> PL/pgSQL function postgis_extensions_upgrade() line 48 at EXECUTE
> SQL state: 42883
> On 12/22/19 8:09 PM, Regina Obe wrote:
> NO NO don’t do that. Those set of libraries aren’t compatible
> with each other.
> The PostGIS 3.0 and 2.5 from 12 are compatible with each other
> however.
> So
> What you want to do is
> cp /usr/lib/postgresql/12/lib/postgis-3.so
> /usr/lib/postgresql/12/lib/postgis-2.5.so
> cp /usr/lib/postgresql/12/lib/postgis_raster-3.so
> /usr/lib/postgresql/12/lib/rtpostgis-2.5.so
> cp /usr/lib/postgresql/12/lib/postgis_topology-3.so
> /usr/lib/postgresql/12/lib/postgis_topology-2.5.so
> Then after the upgrade in each of your databases run:
> And then run it again to rebundle the raster into it’s own extension
> Then if you don’t need raster, you can
> DROP EXTENSION postgis_raster;
> Once you are done upgrading your databases, you can delete thr
> *-2.5.so files you created in the 12 cluster.
> [mailto:postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Bo Guo
> *Sent:* Sunday, December 22, 2019 10:01 PM
> <mailto:postgis-users at lists.osgeo.org>
> Thanks, Regina,
> I copied the three 2.5 lib files from/usr/lib/postgresql/11/lib to
> /usr/lib/postgresql/12/lib:
> guob at yuma:/usr/lib/postgresql/12/lib$ ls -al *post*
> -rw-r--r-- 1 root root 456832 Dec 22 19:49 postgis-2.5.so
> -rw-r--r-- 1 root root 1351536 Oct 28 21:24 postgis-3.so
> -rw-r--r-- 1 root root 847424 Oct 28 21:24 postgis_raster-3.so
> -rw-r--r-- 1 root root 364224 Dec 22 19:49 postgis_topology-2.5.so
> -rw-r--r-- 1 root root 569152 Oct 28 21:24 postgis_topology-3.so
> -rw-r--r-- 1 root root 100264 Nov 12 03:33 postgres_fdw.so
> -rw-r--r-- 1 root root 399136 Dec 22 19:50 rtpostgis-2.5.so
> However, the three lib files are still in the
> loadable_libraries.txt file.
> Bo
> On 12/22/19 7:42 PM, Regina Obe wrote:
> Bo,
> Do you have the postgis-2.5.so, rtpostgis-2.5.so, postgis_topology-2.5.so
> files in
> And
> Those are the files it's complaining about.
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
> Of Bo Guo
> Sent: Sunday, December 22, 2019 9:16 PM
> To:postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] PostgreSQL 12 and PostGIS
> Regina and Stefan,
> I might have run into a similar issues today as I was trying to upgrade
> PostgreSQL 11 w/ PostGIS 2.5 to PostgreSQL 12 w/ PostGIS 3.0.
> The pg_upgradecluster command (sudo pg_upgradecluster -m upgrade 11 main)
> failed its check for the following required libraries:
> could not load library "$libdir/postgis-2.5": ERROR: could not access
> file "$libdir/postgis-2.5": No such file or directory
> could not load library "$libdir/rtpostgis-2.5": ERROR: could not access
> file "$libdir/rtpostgis-2.5": No such file or directory
> could not load library "$libdir/postgis_topology-2.5": ERROR: could not
> access file "$libdir/postgis_topology-2.5": No such file or directory
> I have postgis-2.5 in the /usr/share/postgresql/11/contrib/ folder AND
> /usr/share/postgresql/12/contrib/ folder. I also have postgis-3.0 under
> /usr/share/postgresql/12/contrib/.
> Thanks for your help!
> Bo
> Gistic Research, Inc.
> On 10/4/19 8:16 AM, Regina Obe wrote:
> Stefan,
> Which distro do you get your PostgreSQL 12 from. Im assuming
> apt.postgresql.org
> If so you should report on their mailing list, as that would be a packaging
> bug,not a PostGIS one and no one on the PostGIS project is on the apt team.
> https://www.postgresql.org/list/pgsql-pkg-debian/
> Thanks,
> Regina
> Of Stefan Wolf
> Sent: Friday, October 4, 2019 6:19 AM
> Subject: [postgis-users] PostgreSQL 12 and PostGIS
> Today Ive installed the brand new PostgreSQL 12 on Ubuntu 18.04
> apt-get install postgis will install PostGIS 2.5.2, but the PATH is
> wrong: /usr/share/postgresql/11/
> So CREATE EXTENSION postgis will fail.
> Greetings from Berlin
> -Stefan Wolf-
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
> Regards,
> Bo Guo, PhD, PE
> President
> 2033 E Warner Rd Ste 105
> Tempe, AZ 85284
> www.gisticinc.com <http://www.gisticinc.com>
> www.youtube.com/linearbench <http://www.youtube.com/linearbench>
> Office: 480-656-9962
> Cell: 602-570-4697
> Regards,
> Bo Guo, PhD, PE
> President
> Tempe, AZ 85284
> Cell: 602-570-4697
Regards,
Bo Guo, PhD, PE
President
Tempe, AZ 85284
www.gisticinc.com
Cell: 602-570-4697
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191222/1b11ea77/attachment.html>
