[postgis-users] PostgreSQL 12 and PostGIS
Bo Guo bo.guo at gisticinc.com
Sun Dec 22 21:46:52 PST 2019
Hi, Regina,
After sucessful upgrade to the Dev server, I started upgrading the Test
server which had the following version profile;
select version();
PostgreSQL 11.3 (Ubuntu 11.3-1.pgdg16.04+1) on x86_64-pc-linux-gnu,
compiled by gcc (Ubuntu 5.4.0-6ubuntu1~16.04.11) 5.4.0 20160609, 64-bit
and
select postgis_full_version();
POSTGIS="2.5.2 r17328" [EXTENSION] PGSQL="100" (procs need upgrade for
use with "110") GEOS="3.7.1-CAPI-1.11.1 27a5e771" PROJ="Rel. 4.9.2, 08
September 2015" GDAL="GDAL 1.11.3, released 2015/09/16" LIBXML="2.9.3"
LIBJSON="0.11.99" LIBPROTOBUF="1.2.1" (core procs from "2.5.1 r17027"
need upgrade) TOPOLOGY (topology procs from "2.5.1 r17027" need upgrade)
RASTER (raster procs from "2.5.1 r17027" need upgrade)
However the pg_upgradecluster command failed for different reason as
shown in the last few lines in the log file. I thought Dev and Test
servers had been identical in terms of OS and Postgres/PostGIS install.
Look like there was some difference...
pg_restore: creating VIEW "postgis.geography_columns" pg_restore:
creating VIEW "postgis.geometry_columns" pg_restore: while PROCESSING
TOC: pg_restore: from TOC entry 496; 1259 54951 VIEW geometry_columns
postgres pg_restore: error: could not execute query: ERROR: column
s.consrc does not exist LINE 28: "replace"("split_part"("s"."consrc",
''''::"text... ^ HINT: Perhaps you meant to reference the column
"s.conkey" or the column "s.conbin". Command was: -- For binary upgrade,
must preserve pg_type oid SELECT
pg_catalog.binary_upgrade_set_next_pg_type_oid('54953'::pg_catalog.oid);
-- For binary upgrade, must preserve pg_type array oid SELECT
pg_catalog.binary_upgrade_set_next_array_pg_type_oid('54952'::pg_catalog.oid);
-- For binary upgrade, must preserve pg_class oids SELECT
pg_catalog.binary_upgrade_set_next_heap_pg_class_oid('54951'::pg_catalog.oid);
CREATE VIEW "postgis"."geometry_columns" AS SELECT
("current_database"())::character varying(256) AS "f_table_catalog",
"n"."nspname" AS "f_table_schema", "c"."relname" AS "f_table_name",
"a"."attname" AS "f_geometry_column",
COALESCE("postgis"."postgis_typmod_dims"("a"."atttypmod"), "sn"."ndims",
2) AS "coord_dimension",
COALESCE(NULLIF("postgis"."postgis_typmod_srid"("a"."atttypmod"), 0),
"sr"."srid", 0) AS "srid",
("replace"("replace"(COALESCE(NULLIF("upper"("postgis"."postgis_typmod_type"("a"."atttypmod")),
'GEOMETRY'::"text"), "st"."$ FROM (((((("pg_class" "c" JOIN
"pg_attribute" "a" ON ((("a"."attrelid" = "c"."oid") AND (NOT
"a"."attisdropped")))) JOIN "pg_namespace" "n" ON (("c"."relnamespace" =
"n"."oid"))) JOIN "pg_type" "t" ON (("a"."atttypid" = "t"."oid"))) LEFT
JOIN ( SELECT "s"."connamespace", "s"."conrelid", "s"."conkey",
"replace"("split_part"("s"."consrc", ''''::"text", 2), ')'::"text",
''::"text") AS "type" FROM "pg_constraint" "s" WHERE ("s"."consrc" ~~*
'%geometrytype(% = %'::"text")) "st" ON ((("st"."connamespace" =
"n"."oid") AND ("st"."conrel$ LEFT JOIN ( SELECT "s"."connamespace",
"s"."conrelid", "s"."conkey", ("replace"("split_part"("s"."consrc", ' =
'::"text", 2), ')'::"text", ''::"text"))::integer AS "ndims" FROM
"pg_constraint" "s" WHERE ("s"."consrc" ~~* '%ndims(% = %'::"text"))
"sn" ON ((("sn"."connamespace" = "n"."oid") AND ("sn"."conrelid" = "$
LEFT JOIN ( SELECT "s"."connamespace", "s"."conrelid", "s"."conkey",
("replace"("replace"("split_part"("s"."consrc", ' = '::"text", 2),
')'::"text", ''::"text"), '('::"text", ''::"text$ FROM "pg_constraint"
"s" WHERE ("s"."consrc" ~~* '%srid(% = %'::"text")) "sr" ON
((("sr"."connamespace" = "n"."oid") AND ("sr"."conrelid" = "c$ WHERE
(("c"."relkind" = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char",
'f'::"char", 'p'::"char"])) AND (NOT ("c"."relname"$ -- For binary
upgrade, handle extension membership the hard way ALTER EXTENSION
"postgis" ADD VIEW "postgis"."geometry_columns";
On 12/22/19 9:11 PM, Bo Guo wrote:
> Yeh!  Thanks you, Regina!
> On 12/22/19 8:54 PM, Regina Obe wrote:
>> Okay I ran into that issue too.
>> It happens if you have PostGIS not installed in public.
>> I have the issue ticketed here – I thought I had fixed this already
>> in 3.0.1 (not yet released yet), but evidentally I haven’t or forgot
>> to close this ticket.
>> https://trac.osgeo.org/postgis/ticket/4555
>> The workaround is to do this:
>> CREATE EXTENSION postgis_raster FROM unpackaged VERSION "3.0.0"
>> SCHEMA <schema where you installed postgis>;
>> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
>> *On Behalf Of *Bo Guo
>> *Sent:* Sunday, December 22, 2019 10:36 PM
>> *To:* postgis-users at lists.osgeo.org
>> *Subject:* Re: [postgis-users] PostgreSQL 12 and PostGIS
>> Thanks, Regina!  I am running PostgeSQL 12 now!
>> However, when I ran *SELECT*PostGIS_Extensions_Upgrade(); the second
>> time, I have the following msg.
>> NOTICE: Extension postgis_sfcgal is not available or not packagable
>> for some reason
>> NOTICE: Packaging extension postgis_raster
>> WARNING: 'postgis.gdal_datapath' is already set and cannot be changed
>> until you reconnect
>> WARNING: 'postgis.gdal_enabled_drivers' is already set and cannot be
>> changed until you reconnect
>> WARNING: 'postgis.enable_outdb_rasters' is already set and cannot be
>> ERROR: function public.st_srid(geometry) does not exist
>> LINE 1: ..._makeemptyraster($1, $2, $3, $4, $5, -($5), 0, 0,
>> public.ST_... ^
>> HINT: No function matches the given name and argument types. You
>> might need to add explicit type casts.
>> QUERY: SELECT public.ST_makeemptyraster($1, $2, $3, $4, $5, -($5), 0,
>> 0, public.ST_SRID('POINT(0 0)'::geometry))
>> CONTEXT: SQL statement "CREATE EXTENSION postgis_raster FROM unpackaged"
>> PL/pgSQL function postgis_extensions_upgrade() line 48 at EXECUTE
>> SQL state: 42883
>> On 12/22/19 8:09 PM, Regina Obe wrote:
>>     NO NO  don’t do that.  Those set of libraries aren’t compatible
>>     with each other.
>>     The PostGIS 3.0 and 2.5 from 12 are compatible with each other
>>     however.
>>     So
>>     What you want to do is
>>     cp /usr/lib/postgresql/12/lib/postgis-3.so
>>     /usr/lib/postgresql/12/lib/postgis-2.5.so
>>     cp /usr/lib/postgresql/12/lib/postgis_raster-3.so
>>     /usr/lib/postgresql/12/lib/rtpostgis-2.5.so
>>     cp /usr/lib/postgresql/12/lib/postgis_topology-3.so
>>     /usr/lib/postgresql/12/lib/postgis_topology-2.5.so
>>     Then after the upgrade in each of your databases run:
>>     And then run it again to rebundle the raster into it’s own extension
>>     Then if you don’t need raster, you can
>>     DROP EXTENSION postgis_raster;
>>     Once you are done upgrading your databases, you can delete thr
>>     *-2.5.so files you created in the 12 cluster.
>>     [mailto:postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Bo Guo
>>     *Sent:* Sunday, December 22, 2019 10:01 PM
>>     <mailto:postgis-users at lists.osgeo.org>
>>     Thanks, Regina,
>>     I copied the three 2.5 lib files from/usr/lib/postgresql/11/lib
>>     to /usr/lib/postgresql/12/lib:
>>     guob at yuma:/usr/lib/postgresql/12/lib$ ls -al *post*
>>     -rw-r--r-- 1 root root  456832 Dec 22 19:49 postgis-2.5.so
>>     -rw-r--r-- 1 root root 1351536 Oct 28 21:24 postgis-3.so
>>     -rw-r--r-- 1 root root  847424 Oct 28 21:24 postgis_raster-3.so
>>     -rw-r--r-- 1 root root  364224 Dec 22 19:49 postgis_topology-2.5.so
>>     -rw-r--r-- 1 root root  569152 Oct 28 21:24 postgis_topology-3.so
>>     -rw-r--r-- 1 root root  100264 Nov 12 03:33 postgres_fdw.so
>>     -rw-r--r-- 1 root root  399136 Dec 22 19:50 rtpostgis-2.5.so
>>     However, the three lib files are still in the
>>     loadable_libraries.txt file.
>>     Bo
>>     On 12/22/19 7:42 PM, Regina Obe wrote:
>>         Bo,
>>         Do you have the postgis-2.5.so, rtpostgis-2.5.so, postgis_topology-2.5.so
>>         files in
>>         And
>>         Those are the files it's complaining about.
>>         From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
>>         Of Bo Guo
>>         Sent: Sunday, December 22, 2019 9:16 PM
>>         To:postgis-users at lists.osgeo.org  <mailto:postgis-users at lists.osgeo.org>
>>         Subject: Re: [postgis-users] PostgreSQL 12 and PostGIS
>>         Regina and Stefan,
>>         I might have run into a similar issues today as I was  trying to upgrade
>>         PostgreSQL 11 w/ PostGIS 2.5 to PostgreSQL 12 w/ PostGIS 3.0.
>>         The pg_upgradecluster command (sudo pg_upgradecluster -m upgrade 11 main)
>>         failed its check for the following required libraries:
>>              could not load library "$libdir/postgis-2.5": ERROR:  could not access
>>         file "$libdir/postgis-2.5": No such file or directory
>>              could not load library "$libdir/rtpostgis-2.5": ERROR:  could not access
>>         file "$libdir/rtpostgis-2.5": No such file or directory
>>              could not load library "$libdir/postgis_topology-2.5": ERROR:  could not
>>         access file "$libdir/postgis_topology-2.5": No such file or directory
>>         I have postgis-2.5 in the /usr/share/postgresql/11/contrib/ folder AND
>>         /usr/share/postgresql/12/contrib/ folder.  I also have postgis-3.0 under
>>         /usr/share/postgresql/12/contrib/.
>>         Thanks for your help!
>>         Bo
>>         Gistic Research, Inc.
>>         On 10/4/19 8:16 AM, Regina Obe wrote:
>>         Stefan,
>>         Which distro do you get your PostgreSQL 12 from.  I’m assuming
>>         apt.postgresql.org
>>         If so you should report on their mailing list, as that would be a packaging
>>         bug,not a PostGIS one and no one on the PostGIS project is on the apt team.
>>         https://www.postgresql.org/list/pgsql-pkg-debian/
>>         Thanks,
>>         Regina
>>         Of Stefan Wolf
>>         Sent: Friday, October 4, 2019 6:19 AM
>>         Subject: [postgis-users] PostgreSQL 12 and PostGIS
>>         Today I’ve installed the brand new PostgreSQL 12  on Ubuntu 18.04
>>         “apt-get install postgis”  will install PostGIS 2.5.2, but the  PATH is
>>         wrong:  /usr/share/postgresql/11/…
>>         So CREATE EXTENSION postgis will fail.
>>         Greetings from Berlin
>>         -Stefan Wolf-
>>         _______________________________________________
>>         postgis-users mailing list
>>         https://lists.osgeo.org/mailman/listinfo/postgis-users
>>     Regards,
>>     Bo Guo, PhD, PE
>>     President
>>     2033 E Warner Rd Ste 105
>>     Tempe, AZ 85284
>>     www.gisticinc.com  <http://www.gisticinc.com>
>>     www.youtube.com/linearbench  <http://www.youtube.com/linearbench>
>>     Office: 480-656-9962
>>     Cell: 602-570-4697
>> Regards,
>> Bo Guo, PhD, PE
>> President
>> Tempe, AZ 85284
>> Cell: 602-570-4697
> Regards,
> Bo Guo, PhD, PE
> President
> Tempe, AZ 85284
> www.gisticinc.com
> Cell: 602-570-4697
Regards,
Bo Guo, PhD, PE
President
Tempe, AZ 85284
www.gisticinc.com
Cell: 602-570-4697
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191222/f249aa55/attachment.html>
