[postgis-users] can not get st_split to work.
paul.malm at lfv.se paul.malm at lfv.se
Sun Dec 22 23:52:11 PST 2019
Hi ,
I've created a point-table (point) where I would like to split the lines in table roads.
SQL:
CREATE TABLE  roads_splitted AS
WITH
blade AS (SELECT ST_Collect(the_geom) AS the_geom  FROM  point)
SELECT fid, (ST_Dump
                           (ST_Split(
                                              a.the_geom, (SELECT ST_Collect(b.the_geom) AS geom FROM
        roads AS b WHERE ST_Intersects(a.the_geom, b.the_geom)
                              )).geom
FROM roads AS a
UNION ALL SELECT fid, the_geom FROM roads AS a
WHERE  NOT EXISTS (
           SELECT 1  FROM  point AS b WHERE  ST_Intersects(a.the_geom, b.the_geom)
I'm getting this error message:
ERROR: Splitter line has linear intersection with input SQL state: XX000
Anyone who knows wat I'm doing wrong? Linear intersection with a point and a line?
Kind regards,
Paul
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191223/e729f367/attachment.html>
