[postgis-users] can not get st_split to work.
Regina Obe
lr at pcorp.us
Mon Dec 23 11:31:02 PST 2019
I don't see your blade CTE used at all and both a and b are roads which
wouldn't work with ST_Split, since the blade needs to be one dimension lower
than the thing you are splitting.
So the error you are getting "Splitter line has linear intersection with
input SQL state: XX000"
Is because your intersection literally is returning a line instead a point.
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of paul.malm at lfv.se
Sent: Monday, December 23, 2019 2:52 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] can not get st_split to work.
Hi ,
I've created a point-table (point) where I would like to split the lines in
table roads.
SQL:
CREATE TABLE roads_splitted AS
WITH
blade AS (SELECT ST_Collect(the_geom) AS the_geom FROM point)
SELECT fid, (ST_Dump
(ST_Split(
a.the_geom, (SELECT
ST_Collect(b.the_geom) AS geom FROM
roads AS b WHERE ST_Intersects(a.the_geom, b.the_geom)
)).geom
FROM roads AS a
UNION ALL SELECT fid, the_geom FROM roads AS a
WHERE NOT EXISTS (
SELECT 1 FROM point AS b WHERE ST_Intersects(a.the_geom,
b.the_geom)
I'm getting this error message:
ERROR: Splitter line has linear intersection with input SQL state: XX000
Anyone who knows wat I'm doing wrong? Linear intersection with a point and a
line?
Kind regards,
Paul
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191223/f250b942/attachment.html>
