[postgis-users] PostgreSQL 12 and PostGIS
Bo Guo bo.guo at gisticinc.com
Tue Dec 24 09:31:55 PST 2019
You are right, Regina.  I had installed postgis in the postgres database
in addition to own database.   - Bo
On 12/24/19 10:26 AM, Regina Obe wrote:
> Yah if you had 2.5.3, you definitely didn’t need to bother with the
> create view part.
> I still think you’ve got PostGIS installed in postgres database.
> Try doing this:
> \connect postgres
> DROP EXTENSION postgis;
> See if it drops – I bet it does.  Then run your upgrade again.
> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> *On Behalf Of *Bo Guo
> *Sent:* Monday, December 23, 2019 5:50 PM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Re: [postgis-users] PostgreSQL 12 and PostGIS
> Regina, the saga goes on, but we are getting closer...
> First of all, I removed a stray "topology" schema from the "postgres"
> database.  With that, I am certain that there is no other postgis
> installs on the Test Server.
> Then I ran the postgis extention upgrade in the targeted database (LB)
> and saw the current version is 2.5.3.
> Then I recreated the geometry_columns view by modifying the source you
> provided with the postgis schema prefix "postgis" so the view is not
> created in the "public" schema.
> Finally, I ran sudo pg_upgradecluster -m upgrade 11 main  with the
> following console msg
> Stopping old cluster...
> Creating new PostgreSQL cluster 12/main ...
> /usr/lib/postgresql/12/bin/initdb -D /var/lib/postgresql/12/main
> --auth-local peer --auth-host md5 --encoding UTF8 --lc-collate
> en_US.UTF-8 --lc-ctype en_US.UTF-8
> The files belonging to this database system will be owned by user
> "postgres".
> This user must also own the server process.
> The database cluster will be initialized with locale "en_US.UTF-8".
> The default text search configuration will be set to "english".
> Data page checksums are disabled.
> fixing permissions on existing directory /var/lib/postgresql/12/main
> ... ok
> creating subdirectories ... ok
> selecting dynamic shared memory implementation ... posix
> selecting default max_connections ... 100
> selecting default shared_buffers ... 128MB
> selecting default time zone ... America/Phoenix
> creating configuration files ... ok
> running bootstrap script ... ok
> performing post-bootstrap initialization ... ok
> syncing data to disk ... ok
> Success. You can now start the database server using:
>     pg_ctlcluster 12 main start
> Ver Cluster Port Status Owner    Data directory              Log file
> 12  main    5433 down   postgres /var/lib/postgresql/12/main
> /var/log/postgresql/postgresql-12-main.log
> /usr/lib/postgresql/12/bin/pg_upgrade -b /usr/lib/postgresql/11/bin -B
> /usr/lib/postgresql/12/bin -p 5432 -P 5433 -d /etc/postgresql/11/main
> -D /etc/postgresql/12/main
> Finding the real data directory for the source cluster      ok
> Finding the real data directory for the target cluster      ok
> Performing Consistency Checks
> Checking cluster versions                                   ok
> Checking database user is the install user                  ok
> Checking database connection settings                       ok
> Checking for prepared transactions                          ok
> Checking for reg* data types in user tables                 ok
> Checking for contrib/isn with bigint-passing mismatch       ok
> Checking for tables WITH OIDS                               ok
> Checking for invalid "sql_identifier" user columns          ok
> Creating dump of global objects                             ok
> Creating dump of database schemas
> ok
> Checking for presence of required libraries                 ok
> If pg_upgrade fails after this point, you must re-initdb the
> new cluster before continuing.
> Performing Upgrade
> Analyzing all rows in the new cluster                       ok
> Freezing all rows in the new cluster                        ok
> Deleting files from new pg_xact                             ok
> Copying old pg_xact to new server                           ok
> Setting next transaction ID and epoch for new cluster       ok
> Deleting files from new pg_multixact/offsets                ok
> Copying old pg_multixact/offsets to new server              ok
> Deleting files from new pg_multixact/members                ok
> Copying old pg_multixact/members to new server              ok
> Setting next multixact ID and offset for new cluster        ok
> Resetting WAL archives                                      ok
> Setting frozenxid and minmxid counters in new cluster       ok
> Restoring global objects in the new cluster                 ok
> Restoring database schemas in the new cluster
> postgres
> *failure*
> Consult the last few lines of "pg_upgrade_dump_19530.log" for
> the probable cause of the failure.
> Failure, exiting
> Error: pg_upgrade run failed. Logfiles are in
> /var/log/postgresql/pg_upgradecluster-11-12-main.kFdl
> Error during cluster dumping, removing new cluster
> Cluster is not running.
> Error: could not stop old cluster, please do that manually
> The last few line of the dump log is different from the dump log I
> reported yesterday in the schema name - "public." vs "postgis."  I am
> baffled why today why the installer wanted to install the view in "public"
> pg_restore: creating VIEW "public.geography_columns"
> pg_restore: creating VIEW "public.geometry_columns"
> pg_restore: while PROCESSING TOC:
> pg_restore: from TOC entry 204; 1259 64516 VIEW geometry_columns postgres
> pg_restore: error: could not execute query: ERROR: column s.consrc
> does not exist
> LINE 28: "replace"("split_part"("s"."consrc", ''''::"text...
> HINT:  Perhaps you meant to reference the column "s.conkey" or the
> column "s.conbin".
> Command was:
> -- For binary upgrade, must preserve pg_type oid
> SELECT
> pg_catalog.binary_upgrade_set_next_pg_type_oid('64518'::pg_catalog.oid);
> -- For binary upgrade, must preserve pg_type array oid
> SELECT
> pg_catalog.binary_upgrade_set_next_array_pg_type_oid('64517'::pg_catalog.oid);
> -- For binary upgrade, must preserve pg_class oids
> SELECT
> pg_catalog.binary_upgrade_set_next_heap_pg_class_oid('64516'::pg_catalog.oid);
> CREATE VIEW "public"."geometry_columns" AS
>  SELECT ("current_database"())::character varying(256) AS
> "f_table_catalog",
>     "n"."nspname" AS "f_table_schema",
>     "c"."relname" AS "f_table_name",
>     "a"."attname" AS "f_geometry_column",
> COALESCE("public"."postgis_typmod_dims"("a"."atttypmod"),
> "sn"."ndims", 2) AS "coord_dimension",
> COALESCE(NULLIF("public"."postgis_typmod_srid"("a"."atttypmod"), 0),
> "sr"."srid", 0) AS "srid",
> ("replace"("replace"(COALESCE(NULLIF("upper"("public"."postgis_typmod_type"("a"."atttypmod")),
> 'GEOMETRY'::"text"), "st"."t$
>    FROM (((((("pg_class" "c"
>      JOIN "pg_attribute" "a" ON ((("a"."attrelid" = "c"."oid") AND
> (NOT "a"."attisdropped"))))
>      JOIN "pg_namespace" "n" ON (("c"."relnamespace" = "n"."oid")))
>      JOIN "pg_type" "t" ON (("a"."atttypid" = "t"."oid")))
>      LEFT JOIN ( SELECT "s"."connamespace",
>             "s"."conrelid",
>             "s"."conkey",
>             ("replace"("split_part"("s"."consrc", ' = '::"text", 2),
> ')'::"text", ''::"text"))::integer AS "ndims"
>            FROM "pg_constraint" "s"
>           WHERE ("s"."consrc" ~~* '%ndims(% = %'::"text")) "sn" ON
> ((("sn"."connamespace" = "n"."oid") AND ("sn"."conrelid" = "$
>             "s"."conrelid",
>             "s"."conkey",
> ("replace"("replace"("split_part"("s"."consrc", ' = '::"text", 2),
> ')'::"text", ''::"text"), '('::"text", ''::"text$
>           WHERE ("s"."consrc" ~~* '%srid(% = %'::"text")) "sr" ON
> ((("sr"."connamespace" = "n"."oid") AND ("sr"."conrelid" = "c$
>   WHERE (("c"."relkind" = ANY (ARRAY['r'::"char", 'v'::"char",
> 'm'::"char", 'f'::"char", 'p'::"char"])) AND (NOT ("c"."relname"$
> -- For binary upgrade, handle extension membership the hard way
> ALTER EXTENSION "postgis" ADD VIEW "public"."geometry_columns";
> On 12/23/19 12:26 PM, Regina Obe wrote:
>     That looks good as it’s not showing the scripts procs need upgrade
>     Message any more
>     Do you by chance have more than one database with PostGIS
>     installed?  You’d need to run it on every database if you do.
>     That’s the only thing I can think of that might be causing the issue.
>     It is possible that the update didn’t happen in 2.5.2 and instead
>     in 2.5.3, but I thought it was in 2.5.2.
>     That said – you could overwrite the views in your 11 cluster with
>     the patched ones.
>     geometry_columns
>     https://git.osgeo.org/gitea/postgis/postgis/src/tag/2.5.3/postgis/postgis.sql.in#L5608
>     (make sure to prefix with the schema you have postgis installed in
>     so doesn’t try to create a new view)
>     [mailto:postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Bo Guo
>     *Sent:* Monday, December 23, 2019 10:54 AM
>     <mailto:postgis-users at lists.osgeo.org>
>     Regina,  Since the new cluster was never created so I just
>     upgraded the extension by running your select statement which
>     returned:
>     POSTGIS="2.5.2 r17328" [EXTENSION] PGSQL="110"
>     GEOS="3.7.1-CAPI-1.11.1 27a5e771" PROJ="Rel. 4.9.2, 08 September
>     2015" GDAL="GDAL 1.11.3, released 2015/09/16" LIBXML="2.9.3"
>     LIBJSON="0.11.99" LIBPROTOBUF="1.2.1" TOPOLOGY RASTER
>     Not sure if the postgis gets updated though, as my problem
>     persisted with the same error message.
>     Cheers,
>     Bo
>     On 12/22/19 11:03 PM, Regina Obe wrote:
>         Okay this one is caused by a change in PostgreSQL 12 catalogs.
>         Fixed in PostGIS 2.5.2 I believe -
>         https://git.osgeo.org/gitea/postgis/postgis/raw/tag/2.5.2/NEWS
>         (the pg_constraint change)
>         So to upgrade, what you need to do is
>         1)Reinit your new cluster (as I think at this point your new
>         cluster is in an unstable state)
>         2) Restart up your old cluster and run the upgrade on it -
>         SELECT postgis_extensions_upgrade();  - that will bring it up
>         to 2.5.2 and fix the views so they are compatible with 12.
>         3)Then do your migration again
>         *Bo Guo
>         *Sent:* Monday, December 23, 2019 12:47 AM
>         Hi, Regina,
>         After sucessful upgrade to the Dev server, I started upgrading
>         the Test server which had the following version profile;
>         select version();
>         PostgreSQL 11.3 (Ubuntu 11.3-1.pgdg16.04+1) on
>         x86_64-pc-linux-gnu, compiled by gcc (Ubuntu
>         5.4.0-6ubuntu1~16.04.11) 5.4.0 20160609, 64-bit
>         and
>         select postgis_full_version();
>         POSTGIS="2.5.2 r17328" [EXTENSION] PGSQL="100" (procs need
>         upgrade for use with "110") GEOS="3.7.1-CAPI-1.11.1 27a5e771"
>         PROJ="Rel. 4.9.2, 08 September 2015" GDAL="GDAL 1.11.3,
>         released 2015/09/16" LIBXML="2.9.3" LIBJSON="0.11.99"
>         LIBPROTOBUF="1.2.1" (core procs from "2.5.1 r17027" need
>         upgrade) TOPOLOGY (topology procs from "2.5.1 r17027" need
>         upgrade) RASTER (raster procs from "2.5.1 r17027" need upgrade)
>         However the pg_upgradecluster command failed for different
>         reason as shown in the last few lines in the log file.  I
>         thought Dev and Test servers had been identical in terms of OS
>         and Postgres/PostGIS install.  Look like there was some
>         difference...
>         pg_restore: creating VIEW "postgis.geography_columns"
>         pg_restore: creating VIEW "postgis.geometry_columns"
>         pg_restore: from TOC entry 496; 1259 54951 VIEW
>         s.consrc does not exist
>         ''''::"text...
>         the column "s.conbin".
>         Command was:
>         SELECT
>         pg_catalog.binary_upgrade_set_next_pg_type_oid('54953'::pg_catalog.oid);
>         SELECT
>         pg_catalog.binary_upgrade_set_next_array_pg_type_oid('54952'::pg_catalog.oid);
>         SELECT
>         pg_catalog.binary_upgrade_set_next_heap_pg_class_oid('54951'::pg_catalog.oid);
>         CREATE VIEW "postgis"."geometry_columns" AS
>         "f_table_catalog",
>             COALESCE("postgis"."postgis_typmod_dims"("a"."atttypmod"),
>         COALESCE(NULLIF("postgis"."postgis_typmod_srid"("a"."atttypmod"),
>         0), "sr"."srid", 0) AS "srid",
>         ("replace"("replace"(COALESCE(NULLIF("upper"("postgis"."postgis_typmod_type"("a"."atttypmod")),
>         'GEOMETRY'::"text"), "st"."$
>         AND (NOT "a"."attisdropped"))))
>         "n"."oid")))
>                     "s"."conrelid",
>                     "s"."conkey",
>                     "replace"("split_part"("s"."consrc", ''''::"text",
>         2), ')'::"text", ''::"text") AS "type"
>                   WHERE ("s"."consrc" ~~* '%geometrytype(% =
>         %'::"text")) "st" ON ((("st"."connamespace" = "n"."oid") AND
>         ("st"."conrel$
>                     "s"."conrelid",
>                     "s"."conkey",
>         '::"text", 2), ')'::"text", ''::"text"))::integer AS "ndims"
>         "sn" ON ((("sn"."connamespace" = "n"."oid") AND
>                     "s"."conrelid",
>                     "s"."conkey",
>         = '::"text", 2), ')'::"text", ''::"text"), '('::"text", ''::"text$
>         ON ((("sr"."connamespace" = "n"."oid") AND ("sr"."conrelid" = "c$
>         ALTER EXTENSION "postgis" ADD VIEW "postgis"."geometry_columns";
>         On 12/22/19 9:11 PM, Bo Guo wrote:
>             Yeh!  Thanks you, Regina!
>             On 12/22/19 8:54 PM, Regina Obe wrote:
>                 Okay I ran into that issue too.
>                 It happens if you have PostGIS not installed in public.
>                 I have the issue ticketed here – I thought I had fixed
>                 this already in 3.0.1 (not yet released yet), but
>                 evidentally I haven’t or forgot to close this ticket.
>                 https://trac.osgeo.org/postgis/ticket/4555
>                 The workaround is to do this:
>                 CREATE EXTENSION postgis_raster FROM unpackaged
>                 VERSION "3.0.0" SCHEMA <schema where you installed
>                 postgis>;
>                 Behalf Of *Bo Guo
>                 *Sent:* Sunday, December 22, 2019 10:36 PM
>                 Thanks, Regina!  I am running PostgeSQL 12 now!
>                 However, when I ran
>                 *SELECT*PostGIS_Extensions_Upgrade(); the second time,
>                 I have the following msg.
>                 NOTICE: Extension postgis_sfcgal is not available or
>                 not packagable for some reason
>                 NOTICE: Packaging extension postgis_raster
>                 WARNING: 'postgis.gdal_datapath' is already set and
>                 cannot be changed until you reconnect
>                 WARNING: 'postgis.gdal_enabled_drivers' is already set
>                 and cannot be changed until you reconnect
>                 WARNING: 'postgis.enable_outdb_rasters' is already set
>                 ERROR: function public.st_srid(geometry) does not exist
>                 LINE 1: ..._makeemptyraster($1, $2, $3, $4, $5, -($5),
>                 0, 0, public.ST_... ^
>                 HINT: No function matches the given name and argument
>                 types. You might need to add explicit type casts.
>                 QUERY: SELECT public.ST_makeemptyraster($1, $2, $3,
>                 $4, $5, -($5), 0, 0, public.ST_SRID('POINT(0
>                 0)'::geometry))
>                 CONTEXT: SQL statement "CREATE EXTENSION
>                 postgis_raster FROM unpackaged"
>                 PL/pgSQL function postgis_extensions_upgrade() line 48
>                 at EXECUTE
>                 SQL state: 42883
>                 On 12/22/19 8:09 PM, Regina Obe wrote:
>                     NO NO  don’t do that.  Those set of libraries
>                     aren’t compatible with each other.
>                     The PostGIS 3.0 and 2.5 from 12 are compatible
>                     with each other however.
>                     So
>                     What you want to do is
>                     cp /usr/lib/postgresql/12/lib/postgis-3.so
>                     /usr/lib/postgresql/12/lib/postgis-2.5.so
>                     cp /usr/lib/postgresql/12/lib/postgis_raster-3.so
>                     /usr/lib/postgresql/12/lib/rtpostgis-2.5.so
>                     cp
>                     /usr/lib/postgresql/12/lib/postgis_topology-3.so
>                     /usr/lib/postgresql/12/lib/postgis_topology-2.5.so
>                     Then after the upgrade in each of your databases run:
>                     And then run it again to rebundle the raster into
>                     it’s own extension
>                     Then if you don’t need raster, you can
>                     DROP EXTENSION postgis_raster;
>                     Once you are done upgrading your databases, you
>                     can delete thr *-2.5.so files you created in the
>                     12 cluster.
>                     Behalf Of *Bo Guo
>                     *Sent:* Sunday, December 22, 2019 10:01 PM
>                     PostGIS
>                     Thanks, Regina,
>                     I copied the three 2.5 lib files
>                     from/usr/lib/postgresql/11/lib to
>                     /usr/lib/postgresql/12/lib:
>                     guob at yuma:/usr/lib/postgresql/12/lib$ ls -al *post*
>                     -rw-r--r-- 1 root root  456832 Dec 22 19:49
>                     postgis-2.5.so
>                     -rw-r--r-- 1 root root 1351536 Oct 28 21:24
>                     postgis-3.so
>                     -rw-r--r-- 1 root root  847424 Oct 28 21:24
>                     postgis_raster-3.so
>                     -rw-r--r-- 1 root root  364224 Dec 22 19:49
>                     -rw-r--r-- 1 root root  569152 Oct 28 21:24
>                     -rw-r--r-- 1 root root  100264 Nov 12 03:33
>                     postgres_fdw.so
>                     -rw-r--r-- 1 root root  399136 Dec 22 19:50
>                     rtpostgis-2.5.so
>                     However, the three lib files are still in the
>                     loadable_libraries.txt file.
>                     Bo
>                     On 12/22/19 7:42 PM, Regina Obe wrote:
>                         Bo,
>                         Do you have the postgis-2.5.so, rtpostgis-2.5.so, postgis_topology-2.5.so
>                         files in
>                         And
>                         Those are the files it's complaining about.
>                         From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
>                         Of Bo Guo
>                         Sent: Sunday, December 22, 2019 9:16 PM
>                         To:postgis-users at lists.osgeo.org  <mailto:postgis-users at lists.osgeo.org>
>                         Subject: Re: [postgis-users] PostgreSQL 12 and PostGIS
>                         Regina and Stefan,
>                         I might have run into a similar issues today as I was  trying to upgrade
>                         PostgreSQL 11 w/ PostGIS 2.5 to PostgreSQL 12 w/ PostGIS 3.0.
>                         The pg_upgradecluster command (sudo pg_upgradecluster -m upgrade 11 main)
>                         failed its check for the following required libraries:
>                              could not load library "$libdir/postgis-2.5": ERROR:  could not access
>                         file "$libdir/postgis-2.5": No such file or directory
>                              could not load library "$libdir/rtpostgis-2.5": ERROR:  could not access
>                         file "$libdir/rtpostgis-2.5": No such file or directory
>                              could not load library "$libdir/postgis_topology-2.5": ERROR:  could not
>                         access file "$libdir/postgis_topology-2.5": No such file or directory
>                         I have postgis-2.5 in the /usr/share/postgresql/11/contrib/ folder AND
>                         /usr/share/postgresql/12/contrib/ folder.  I also have postgis-3.0 under
>                         /usr/share/postgresql/12/contrib/.
>                         Thanks for your help!
>                         Bo
>                         Gistic Research, Inc.
>                         On 10/4/19 8:16 AM, Regina Obe wrote:
>                         Stefan,
>                         Which distro do you get your PostgreSQL 12 from.  I’m assuming
>                         apt.postgresql.org
>                         If so you should report on their mailing list, as that would be a packaging
>                         bug,not a PostGIS one and no one on the PostGIS project is on the apt team.
>                         https://www.postgresql.org/list/pgsql-pkg-debian/
>                         Thanks,
>                         Regina
>                         Of Stefan Wolf
>                         Sent: Friday, October 4, 2019 6:19 AM
>                         Subject: [postgis-users] PostgreSQL 12 and PostGIS
>                         Today I’ve installed the brand new PostgreSQL 12  on Ubuntu 18.04
>                         “apt-get install postgis”  will install PostGIS 2.5.2, but the  PATH is
>                         wrong:  /usr/share/postgresql/11/…
>                         So CREATE EXTENSION postgis will fail.
>                         Greetings from Berlin
>                         -Stefan Wolf-
>                         _______________________________________________
>                         postgis-users mailing list
>                         https://lists.osgeo.org/mailman/listinfo/postgis-users
>                     Regards,
>                     Bo Guo, PhD, PE
>                     President
>                     2033 E Warner Rd Ste 105
>                     Tempe, AZ 85284
>                     www.gisticinc.com  <http://www.gisticinc.com>
>                     www.youtube.com/linearbench  <http://www.youtube.com/linearbench>
>                     Office: 480-656-9962
>                     Cell: 602-570-4697
>                 Regards,
>                 Bo Guo, PhD, PE
>                 President
>                 Tempe, AZ 85284
>                 Cell: 602-570-4697
>             Regards,
>             Bo Guo, PhD, PE
>             President
>             Tempe, AZ 85284
>             Cell: 602-570-4697
>         Regards,
>         Bo Guo, PhD, PE
>         President
>         Tempe, AZ 85284
>         Cell: 602-570-4697
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191224/b5f0f001/attachment.html>
