[postgis-users] Selecting as GeoJSON with Transformation
Sean Montague
couloir007 at gmail.com
Mon Feb 11 06:59:48 PST 2019
Hi Nicolas,
Thank you for the response. I have tried working with the example but I'm
unable to get it to run. In the example you provided I keep getting.
ERROR: missing FROM-clause entry for table "trails_01"
LINE 3: ST_AsGeoJSON(ST_Transform(ST_SetSRID(trails_01.geom...
which searches lead me to there is an ordering issue
Thanks!
Sean
On Mon, Feb 11, 2019 at 4:00 AM Nicolas Ribot <nicolas.ribot at gmail.com>
wrote:
> On Fri, 8 Feb 2019 at 23:48, Sean Montague <couloir007 at gmail.com> wrote:
>> It has been many years since I last worked with postGIS, I don't do GIS
>> for a living anymore but I still like to have fun with it. I'm looking to
>> export some old data I have as GeoJSON and projecting it to display in a
>> Google Map Overlay. I can get the two individual queries below to work, but
>> I cannot figure out how to combine them. I want to transform and output to
>> GeoJSON with attributes stored in the DB.
>> SELECT
>> ST_AsGeoJSON(ST_Transform(ST_SetSRID(trails_01.geom, 26918), 4326)),
>> trails_01.name,
>> trails_01.id
>> FROM
>> topology.trails_01;
>> SELECT jsonb_build_object(
>> 'type', 'FeatureCollection',
>> 'features', jsonb_agg(features.feature)
>> FROM (
>> 'type', 'Feature',
>> 'id', gid,
>> 'geometry', ST_AsGeoJSON(geom)::jsonb,
>> 'properties', to_jsonb(inputs) - 'gid' - 'geom'
>> ) AS feature
>> FROM (SELECT * FROM topology.trails_01) inputs) features;
>> Any help would be appreciated as I start down this path of reteaching
>> myself postGIS.
>> Thank you,
>> Sean
> Hi,
> Something like:
> with tmp1 as (
> select 'Feature' as "type",
> 4326), 6)::json as "geometry",
> select json_strip_nulls(row_to_json(t))
> from (select id, inputs) t
> ) as "properties"
> from topology.trails_01 t
> ), tmp2 as (
> select 'FeatureCollection' as "type",
> array_to_json(array_agg(t)) as "features"
> from tmp1 t
> ) select row_to_json(t)
> from tmp2 t;
> Nicolas
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190211/3dd987ff/attachment.html>
