[postgis-users] Selecting as GeoJSON with Transformation
Nicolas Ribot
nicolas.ribot at gmail.com
Mon Feb 11 08:29:19 PST 2019
Hmm sorry.
I pasted your table name without checking.
topology.trails_01 is aliased as "t" in the query:
with tmp1 as (
select 'Feature' as "type",
ST_AsGeoJSON(ST_Transform(ST_SetSRID(t.geom, 26918), 4326),
6)::json as "geometry",
select json_strip_nulls(row_to_json(t))
from (select id, inputs) t
) as "properties"
from topology.trails_01 t
), tmp2 as (
select 'FeatureCollection' as "type",
array_to_json(array_agg(t)) as "features"
from tmp1 t
) select row_to_json(t)
from tmp2 t;
Nicolas
On Mon, 11 Feb 2019 at 16:00, Sean Montague <couloir007 at gmail.com> wrote:
> Hi Nicolas,
> Thank you for the response. I have tried working with the example but I'm
> unable to get it to run. In the example you provided I keep getting.
> ERROR: missing FROM-clause entry for table "trails_01"
> LINE 3: ST_AsGeoJSON(ST_Transform(ST_SetSRID(trails_01.geom...
> which searches lead me to there is an ordering issue
> Thanks!
> Sean
> On Mon, Feb 11, 2019 at 4:00 AM Nicolas Ribot <nicolas.ribot at gmail.com>
> wrote:
>> On Fri, 8 Feb 2019 at 23:48, Sean Montague <couloir007 at gmail.com> wrote:
>>> It has been many years since I last worked with postGIS, I don't do GIS
>>> for a living anymore but I still like to have fun with it. I'm looking to
>>> export some old data I have as GeoJSON and projecting it to display in a
>>> Google Map Overlay. I can get the two individual queries below to work, but
>>> I cannot figure out how to combine them. I want to transform and output to
>>> GeoJSON with attributes stored in the DB.
>>> SELECT
>>> ST_AsGeoJSON(ST_Transform(ST_SetSRID(trails_01.geom, 26918), 4326)),
>>> trails_01.name,
>>> trails_01.id
>>> FROM
>>> topology.trails_01;
>>> SELECT jsonb_build_object(
>>> 'type', 'FeatureCollection',
>>> 'features', jsonb_agg(features.feature)
>>> FROM (
>>> 'type', 'Feature',
>>> 'id', gid,
>>> 'geometry', ST_AsGeoJSON(geom)::jsonb,
>>> 'properties', to_jsonb(inputs) - 'gid' - 'geom'
>>> ) AS feature
>>> FROM (SELECT * FROM topology.trails_01) inputs) features;
>>> Any help would be appreciated as I start down this path of reteaching
>>> myself postGIS.
>>> Thank you,
>>> Sean
>> Hi,
>> Something like:
>> with tmp1 as (
>> 4326), 6)::json as "geometry",
>> ) as "properties"
>> ), tmp2 as (
>> from tmp1 t
>> from tmp2 t;
>> Nicolas
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190211/9b651e85/attachment.html>
