[postgis-users] Selecting as GeoJSON with Transformation
Sean Montague
couloir007 at gmail.com
Mon Feb 11 08:37:32 PST 2019
That worked. Thank you very much.
Sean
On Mon, Feb 11, 2019 at 11:29 AM Nicolas Ribot <nicolas.ribot at gmail.com>
wrote:
> Hmm sorry.
> I pasted your table name without checking.
> topology.trails_01 is aliased as "t" in the query:
> with tmp1 as (
> select 'Feature' as "type",
> ST_AsGeoJSON(ST_Transform(ST_SetSRID(t.geom, 26918), 4326), 6)::json as "geometry",
> select json_strip_nulls(row_to_json(t))
> from (select id, inputs) t
> ) as "properties"
> from topology.trails_01 t
> ), tmp2 as (
> select 'FeatureCollection' as "type",
> array_to_json(array_agg(t)) as "features"
> from tmp1 t
> ) select row_to_json(t)
> from tmp2 t;
> Nicolas
> On Mon, 11 Feb 2019 at 16:00, Sean Montague <couloir007 at gmail.com> wrote:
>> Hi Nicolas,
>> Thank you for the response. I have tried working with the example but I'm
>> unable to get it to run. In the example you provided I keep getting.
>> ERROR: missing FROM-clause entry for table "trails_01"
>> LINE 3: ST_AsGeoJSON(ST_Transform(ST_SetSRID(trails_01.geom...
>> which searches lead me to there is an ordering issue
>> Thanks!
>> Sean
>> On Mon, Feb 11, 2019 at 4:00 AM Nicolas Ribot <nicolas.ribot at gmail.com>
>> wrote:
>>> On Fri, 8 Feb 2019 at 23:48, Sean Montague <couloir007 at gmail.com> wrote:
>>>> It has been many years since I last worked with postGIS, I don't do GIS
>>>> for a living anymore but I still like to have fun with it. I'm looking to
>>>> export some old data I have as GeoJSON and projecting it to display in a
>>>> Google Map Overlay. I can get the two individual queries below to work, but
>>>> I cannot figure out how to combine them. I want to transform and output to
>>>> GeoJSON with attributes stored in the DB.
>>>> SELECT
>>>> ST_AsGeoJSON(ST_Transform(ST_SetSRID(trails_01.geom, 26918), 4326)),
>>>> trails_01.name,
>>>> trails_01.id
>>>> FROM
>>>> topology.trails_01;
>>>> SELECT jsonb_build_object(
>>>> 'type', 'FeatureCollection',
>>>> 'features', jsonb_agg(features.feature)
>>>> FROM (
>>>> 'type', 'Feature',
>>>> 'id', gid,
>>>> 'geometry', ST_AsGeoJSON(geom)::jsonb,
>>>> 'properties', to_jsonb(inputs) - 'gid' - 'geom'
>>>> ) AS feature
>>>> FROM (SELECT * FROM topology.trails_01) inputs) features;
>>>> Any help would be appreciated as I start down this path of reteaching
>>>> myself postGIS.
>>>> Thank you,
>>>> Sean
>>> Hi,
>>> Something like:
>>> with tmp1 as (
>>> ) as "properties"
>>> ), tmp2 as (
>>> from tmp1 t
>>> from tmp2 t;
>>> Nicolas
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190211/81df22fc/attachment.html>
