[postgis-users] Attempting to Connect to POSTGIS Database Table from BIRT To Create a report from an POSTGIS attribute table - connection throws error (with only spatial enabled tables)
mfene5101 at gmail.com
Fri Feb 8 23:24:06 PST 2019
This is my first use of the postgis-users list
I am currently using BIRT reporting tool to connect to Postgresql 9.6. To
reporting tool works fine on NON-POSTGIS enabled tables.
I enabled full tracing on the database to capture the database log as well
as the error thrown by BIRT.
BIRT uses the postgresjdbc driver to connect to Postgresql. I suspect the
issue is at the jdbc driver level but I am unsure.
I have read some google entries regarding the installation of the
postgisjdbc driver.but it is unclear which version I should use - or how to
install it.
My current environment is: postgresql9.6 postgis2.3 centos7
Extract of the postgresql (server side) trace log: (note: I renamed table
name to 'XXX' to maintain security):
2019-02-08 21:49:31.951
PST,"fenem","dbplmspatial",21824,"192.168.1.129:50737",5c5e69eb.5540,6,"PARS
E",2019-02-08 21:49:31 PST,7/25,0,ERROR,42P01,"relation ""public.XXX"" does
not exist",,,,,,"select * from public.XXX",15,,"PostgreSQL JDBC Driver"
Client side error:
A BIRT exception occurred.
Plug-in Provider:Eclipse BIRT Project
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:4.7.0.v201706222054
Error Code:odaconsumer.CannotGetResultSetMetaData
Error Message:Cannot get the result set metadata.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does
not return a ResultSet object.
SQL error #1:ERROR: relation "public.tollbrotherspacifichighranchparcels"
does not exist
Position: 15
org.postgresql.util.PSQLException: ERROR: relation "public.XXX" does not
exist
Position: 15
Thanks in advance for your consideration.
Michael Fene'
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190208/0f293073/attachment.html>
