[postgis-users] Multicurve
Paul Ramsey
pramsey at cleverelephant.ca
Fri Jan 11 13:20:05 PST 2019
Where are these “shapefiles with curves” you are seeing? the original spec did not include them… any documentation you can point to?
https://www.esri.com/library/whitepapers/pdfs/shapefile.pdf <https://www.esri.com/library/whitepapers/pdfs/shapefile.pdf>
P.
> On Jan 11, 2019, at 4:13 PM, Clifford Snow <clifford at snowandsnow.us> wrote:
> Lately some of the data from local governments contain road data with multicurve geometry. Attempting to load with shp2pgsql fails.
> I've been using ogr2ogr with the -nlt option to specify MULTILINESTRING.
> Is there any better work arounds? According to PostGIS, it does support multicurve geometries.
> Thanks in advance,
> Clifford
> @osm_seattle
> osm_seattle.snowandsnow.us <http://osm_seattle.snowandsnow.us/>
> OpenStreetMap: Maps with a human touch
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190111/c56972df/attachment.html>
