[postgis-users] Multicurve
Simon (SPDBA) Greener
simon at spatialdbadvisor.com
Fri Jan 11 15:49:07 PST 2019
Nomenclature problem?
ESRI calls a linestring an Arc!
Sent from BlueMail
On 12 Jan. 2019, 08:21, at 08:21, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>Where are these “shapefiles with curves” you are seeing? the original
>spec did not include them… any documentation you can point to?
>https://www.esri.com/library/whitepapers/pdfs/shapefile.pdf
><https://www.esri.com/library/whitepapers/pdfs/shapefile.pdf>
>P.
>> On Jan 11, 2019, at 4:13 PM, Clifford Snow <clifford at snowandsnow.us>
>wrote:
>> Lately some of the data from local governments contain road data with
>multicurve geometry. Attempting to load with shp2pgsql fails.
>> I've been using ogr2ogr with the -nlt option to specify
>MULTILINESTRING.
>> Is there any better work arounds? According to PostGIS, it does
>support multicurve geometries.
>> Thanks in advance,
>> Clifford
>> @osm_seattle
>> osm_seattle.snowandsnow.us <http://osm_seattle.snowandsnow.us/>
>> OpenStreetMap: Maps with a human touch
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190112/59b43cea/attachment.html>
