[postgis-users] Geography/geometry
Simon Greener
simon at spatialdbadvisor.com
Mon Jan 21 15:26:56 PST 2019
Thanks.
I couldn't see how this would help as this is structural not mathematical.
But I am trying to bring the parts back together.
S
On Tue, 22 Jan 2019 10:01:36 +1100, Martin Davis <mtnclimb at gmail.com> wrote:
> Could the problem be the use of the ogr2ogr option -nlt POLYGON ? Some of the input geometries are multipolygons, and it sounds like the way to >handle this with ogr2ogr is to use GEOMETRY or PROMOTE_TO_MULTI [1][2]
> [1] https://www.gdal.org/ogr2ogr.html
> [2] https://gis.stackexchange.com/a/195223
> On Mon, Jan 21, 2019 at 1:00 PM Simon Greener <simon at spatialdbadvisor.com> wrote:
>> The shapefile (from OSM) can be accessed here:
>> https://www.dropbox.com/s/jbptp3ycmc8cqzi/gis_osm_county_a_free_1.rar?dl=0
>> The command used to load is:
>> ogr2ogr -overwrite -progress -skipfailures -a_srs "EPSG:4326" ^
>> -f "PostgreSQL" PG:"dbname='gisdb' host='localhost' port='5432' user='postgres' ^
>> gis_osm_county_a_free_1.shp -nln data.osm_county -nlt POLYGON ^
>> -lco LAUNDER=YES -lco GEOMETRY_NAME=geog4326 -lco GEOM_TYPE=geography -lco FID=ID -lco DIM=2 -lco SPATIAL_INDEX=YES
>> Am I missing something with the ogr2ogr command for the load?
Regards
Simon
Spatial Advice & Solutions Architecture
Database Spatial Stored Procedure Designer
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE FME
Awarded "2011 Oracle Spatial Excellence Award for Education and Research"
A: 39 Cliff View Drive, Allens Rivulet, 7150, Tas, Aust
W: www.spdba.com.au
E: simon at spdba.com.au
V: +61 362 396 397
M: +61 418 396 391
GITC Supplier: T1005
Skype: sggreener
Long: 147.20515 (147° 12' 18" E)
Lat: -43.01530 (43° 00' 55" S)
GeoHash: r22em9r98wg
NAC:W80CK 7SWP3
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190122/603b836c/attachment.html>
