[postgis-users] PARTIALLY RESOLVED: Geography/geometry
Simon Greener
simon at spatialdbadvisor.com
Mon Jan 21 19:05:58 PST 2019
I replaced the shapefile load script dropping ogr2ogr in favor of shp2pgshp.
This appears to have given me clean multipolygons as nothing was reported by the following:
select ST_ISValidReason(a.geog4326::geometry)
from data.osm_county as a
where ST_IsValidReason(a.geog4326::geometry) <> 'Valid Geometry'
I discovered though this process that the original shapefile had 10 counties that were duplicated.
I used postgresql to delete the duplicates.
All my SQL appears to be working.
Perhaps Martin is right: there is something wrong with the ogr2ogr load (though I switched from -nlt POLYGON to -nlt PROMOTE_TO_MULTI and it didn't make any difference).
I think this request for help can now be closed.
Thanks to all.
regards
Simon
> Just ’select geom’ will return the extended hexwkb (which we should have JTS support as a matter of convenience). If you need pure standard hex >wkb, then
> select encode(st_asbinary(geom), ‘hex’)
> will do that
> P
>> On Jan 21, 2019, at 2:39 PM, Martin Davis <mtnclimb at gmail.com> wrote:
>> Not much help, I'm afraid. I need the geometry in WKBHex. Not sure offhand how to get that out of PostGIS.
>> Just post the WKT and let's see what that looks like.
>> On Mon, Jan 21, 2019 at 1:52 PM Simon Greener <simon at spatialdbadvisor.com> wrote:
>>> Try here for an example:
>>> https://www.dropbox.com/s/n234bc6i5hj7y4o/Ireland.sql?dl=0
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
Regards
Simon
Spatial Advice & Solutions Architecture
Database Spatial Stored Procedure Designer
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE FME
Awarded "2011 Oracle Spatial Excellence Award for Education and Research"
A: 39 Cliff View Drive, Allens Rivulet, 7150, Tas, Aust
W: www.spdba.com.au
E: simon at spdba.com.au
V: +61 362 396 397
M: +61 418 396 391
GITC Supplier: T1005
Skype: sggreener
Long: 147.20515 (147° 12' 18" E)
Lat: -43.01530 (43° 00' 55" S)
GeoHash: r22em9r98wg
NAC:W80CK 7SWP3
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190122/17eb6e21/attachment.html>
