[postgis-users] ST_NPoints from polygons
Etienne B. Racine etiennebr at gmail.com
Mon Jul 1 04:45:44 PDT 2019
Hi list,
I'm implementing postgis compatible functions for R, so I wanted to make
sure I had the right behavior. I wanted to check that the behavior of
ST_NPoints was consistent with expectations.
SELECT ST_NPoints('POLYGON((0 0, 1 1, 2 0, 0 0))'::geometry);
#>  st_npoints
#>           4
I would have expected that the repeated vertex wouldn't be counted (a
triangle would have 3 vertices). The doc (*Return the number of points in a
geometry*) seems to imply that the behavior is correct though, since a
point isn't necessarly a vertex; but it still leaves room to interpretation.
Etienne
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190701/0db6bb49/attachment.html>
