[postgis-users] PostGIS 3.0.0alpha3 released
Regina Obe
lr at pcorp.us
Mon Jul 1 09:42:07 PDT 2019
The PostGIS development team is pleased to release PostGIS 3.0.0alpha3.
http://www.postgis.net/2019/07/01/postgis-3.0.0alpha3/
This release works with PostgreSQL 9.5-12beta2 and GEOS >= 3.6
Best served with [PostgreSQL 12beta2]
https://www.postgresql.org/developer/beta/
**3.0.0alpha3**
* [source
download]https://download.osgeo.org/postgis/source/postgis-3.0.0alpha3.tar.g
z
* [NEWS]
https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.0.0alpha3/NEWS
* PDF docs [en]
https://download.osgeo.org/postgis/docs/postgis-3.0.0alpha3.pdf
* [html doc download]
https://download.osgeo.org/postgis/docs/doc-html-3.0.0alpha3.tar.gz
* [epub doc download]
https://download.osgeo.org/postgis/docs/postgis-3.0.0alpha3.epub
* [Changelog]https://svn.osgeo.org/postgis/tags/3.0.0alpha3/ChangeLog
View all [closed tickets for 3.0.0]
https://trac.osgeo.org/postgis/query?status=closed&resolution=fixed&mileston
e=PostGIS+3.0.0&col=id&col=summary&col=milestone&col=status&col=type&col=pri
ority&col=component&order=priority
Main changes since PostGIS 3.0.0alpha2 release are as follows:
* 4438, Update serialization to support extended flags area (Paul Ramsey)
* 3437, Speed up ST_Intersects with Points (Raúl Marín)
* 4352, Use CREATE OR REPLACE AGGREGATE for PG12+ (Raúl Marín)
* 4441, Make GiST penalty friendly to multi-column indexes and build
single-column
ones faster. (Darafei Praliaskouski)
* 4372, PROJ6: Speed improvements (Raúl Marín)
* 4414, Include version number in address_standardizer lib (Raúl Marín)
* 4334, Fix upgrade issues related to renamed parameters (Raúl Marín)
* 4388, AddRasterConstraints: Ignore NULLs when generating constraints (Raúl
Marín)
* 4327, Avoid pfree'ing the result of getenv (Raúl Marín)
* 4406, Throw on invalid characters when decoding geohash (Raúl Marín)
* 4429, Avoid resource leaks with PROJ6 (Raúl Marín)
* 4443, Fix wagyu configure dropping CPPFLAGS (Raúl Marín)
* 4440, Type lookups in FDW fail (Paul Ramsey)
* 4442, raster2pgsql now skips NODATA tiles. Use -k option if you still want
them in database for some reason. (Darafei Praliaskouski)
Happy Testing,
PostGIS Development Team
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190701/b806bc46/attachment.html>
