[postgis-users] creating points from polygons, storing all attributes
Hugues François
hugues.francois at irstea.fr
Thu Jul 4 05:30:35 PDT 2019
Of course if you select * from a table where a column "the_geom" exists and perform in the same time some geometry computation with an alias named "the_geom" (i.e. "AS the_geom"), then you have two columns named "the_geom".
Best regards,
Hugues
De: "paul malm" <paul.malm at lfv.se>
À: "PostGIS Users Discussion" <postgis-users at lists.osgeo.org>
Envoyé: Jeudi 4 Juillet 2019 14:26:07
Objet: Re: [postgis-users] creating points from polygons, storing all attributes
Thanks, I’ve tried that but get this error:
ERROR: column "the_geom" is specified more than once SQL state: 42701
/Paul
Från: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] För Derek Watling
Skickat: den 4 juli 2019 13:55
Till: PostGIS Users Discussion
Ämne: Re: [postgis-users] creating points from polygons, storing all attributes
CREATE TABLE NewPointLayer AS SELECT *, ST_PointOnSurface(the_geom)::geometry(Point,32632) AS the_geom FROM OldPolygonLayer
From: postgis-users <postgis-users-bounces at lists.osgeo.org> On Behalf Of paul.malm at lfv.se
Sent: Thursday, 04 July 2019 13:47
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] creating points from polygons, storing all attributes
I would like to create a point table from a polygon table. One point in each polygon
Query = CREATE TABLE NewPointLayer AS SELECT ST_PointOnSurface(the_geom)::geometry(Point,32632) AS the_geom FROM OldPolygonLayer
But how do I write the query to get all the attributes from OldPolygonLayer to the NewPointLayer?
Thanks in advance,
Paul
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190704/7cf02853/attachment.html>
