[postgis-users] ST_Maxdistance schema hardcoding error
Philip M. Hurvitz
phurvitz at uw.edu
Fri Jul 12 11:52:46 PDT 2019
Hi all, I found that ST_MaxDistance() was failing for a database that had the PostGIS extension installed in the schema 'postgis'.
SELECT ST_MaxDistance('POINT(0 0)'::geometry, 'LINESTRING ( 2 0, 0 2 )'::geometry);
ERROR: function public.st_convexhull(geometry) does not exist
LINE 1: SELECT public._ST_MaxDistance(public.ST_ConvexHull($1), publ...
HINT: No function matches the given name and argument types. You might need to add explicit type casts.
QUERY: SELECT public._ST_MaxDistance(public.ST_ConvexHull($1), public.ST_ConvexHull($2))
CONTEXT: SQL function "st_maxdistance" during startup
Time: 147.448 ms
It seems that the function is expecting to find the ST_ConvexHull function in the public schema.
As a workaround I edited the code for the _ST_MaxDistance and ST_ConvexHull to create identical functions in the public schema and now things work as expected:
st_maxdistance
2
I had originally installed PostGIS in the public schema but then relocated the extension to the postgis schema -- could this be the reason? Other functions are acting strangely, e.g., postgis_version works OK
select postgis_version();
postgis_version
2.4 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
but postgis_full_version fails
select postgis_full_version();
ERROR: function public.postgis_lib_version() does not exist
LINE 1: SELECT public.postgis_lib_version()
QUERY: SELECT public.postgis_lib_version()
CONTEXT: PL/pgSQL function postgis_full_version() line 25 at SQL statement
Does anyone know if there is a fix for rewriting the functions that are looking in public for functions that are located in the postgis schema?
Thanks for any info!
Philip M. Hurvitz
Research Assistant Professor, Urban Design and Planning
Research Scientist, Civil Engineering (TRAC)
http://gis.washington.edu/phurvitz/contact
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190712/6b6f0e12/attachment.html>
