[postgis-users] [Partially solved] Re: Upgrade from Postgis 1.5.1-5 to 2.3.1
Michel Philippenko
michel.ing93 at gmail.com
Thu Jul 18 10:51:07 PDT 2019
Hi
https://github.com/postgis/postgis/pull/448
Le jeu. 18 juil. 2019 à 19:42, Darafei "Komяpa" Praliaskouski <me at komzpa.net>
a écrit :
> Hi,
> I don't see your pull request. Can you send over a link to it?
> On Thu, Jul 18, 2019 at 8:22 PM Michel Philippenko <michel.ing93 at gmail.com>
> wrote:
>> Привет Darafei
>> Sorry for the delay. I pushed my pull request in order to suggest a
>> modification of the documentation, as we talked about previously.
>> You asked me :
>> - what is IGN <== I putted a link in the text I proposed.
>> - why it produces invalid SRIDs <== I'm not expert of cartography and
>> cannot explain the technical reason why in old databases using french IGN
>> we have SRID out of range. It seems that French IGN had specific system
>> about 10 years ago. I putted in my pull request an example of an issue. As
>> I seemed to me, these SRID correspond mostly to french islands which are
>> far from France (but not only islands also few parts of France itself). The
>> warnings I had on my screen mentionned these ones for example : 310024140,
>> 310642254, ..., 110600000, 110013000, 110013000, and many others.
>> - what do you lose by removing them <== I had no more problems when doing
>> my hard upgrade of my database :-) As I could understand, the old SRIDs
>> which have been out of range correspond to new SRID which are inside the
>> right range ; it seems that the IGN cartography data are still there but
>> with another format :
>> *OLD database :* SELECT srtext FROM spatial_ref_sys where srid=
>> *310423221*;
>> returns :
>> PROJCS["St Pierre et Miquelon 1950",GEOGCS["St Pierre et Miquelon 1950
>> ",DATUM["St Pierre et Miquelon 1950",SPHEROID["Clarke
>> 1866",6378206.4000,294.9786982000000,AUTHORITY["IGNF","ELG004"]],TOWGS84[-95.5930,573.7630,173.4420,-0.9602,1.2510,-1.3918,42.626500],AUTHORITY["IGNF","REG423"]],PRIMEM["Greenwich",0.000000000,AUTHORITY["IGNF","LGO01"]],UNIT["degree",0.01745329251994330],AXIS["Longitude",EAST],AXIS["Latitude",NORTH],AUTHORITY["IGNF","STPM50GEO"]],PROJECTION["Transverse_Mercator",AUTHORITY["IGNF","PRC0221"]],PARAMETER["semi_major",6378206.4000],PARAMETER["semi_minor",6356583.8000],PARAMETER["latitude_of_origin",0.000000000],PARAMETER["central_meridian",-57.000000000],PARAMETER["scale_factor",0.99960000],PARAMETER["false_easting",500000.000],PARAMETER["false_northing",0.000],UNIT["metre",1],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["IGNF","STPM50UTM21"]]
>> *New database after hard upgrade :* SELECT srtext FROM spatial_ref_sys
>> where srid=*911423*;
>> returns :
>> GEOCCS["St Pierre et Miquelon 1950",DATUM["St Pierre et Miquelon
>> 1866",6378206.4000,294.9786982000000,AUTHORITY["IGNF","ELG004"]],TOWGS84[-95.5930,573.7630,173.4420,-0.9602,1.2510,-1.3918,42.626500],AUTHORITY["IGNF","REG423"]],PRIMEM["Greenwich",0.000000000,AUTHORITY["IGNF","LGO01"]],UNIT["metre",1],AXIS["X",OTHER],AXIS["Y",EAST],AXIS["Z",NORTH],AUTHORITY["IGNF","STPM50"]]
>> Thank you for your attention,
>> with best regards,
>> Mikhael
>> Le sam. 10 nov. 2018 à 19:11, Darafei "Komяpa" Praliaskouski <
>> me at komzpa.net> a écrit :
>>> Привет,
>>> That chapter is part of PostGIS documentation which is part of PostGIS
>>> itself. You can edit here:
>>> https://github.com/postgis/postgis/blob/svn-trunk/doc/installation.xml
>>> (just push [Edit], do your changes and [Save] -> [New pull request]).
>>> Please also mention what is IGN and why it produces invalid SRIDs, and
>>> what do you lose by removing them. :)
>>> пт, 9 нояб. 2018 г. в 19:24, Michel Philippenko <michel.ing93 at gmail.com
>>>> Hello,
>>>> I have managed to avoid errors in relation with
>>>> spatial_ref_sys_srid_check and I asked the administrators of the website
>>>> postgis.net to add some information in this page :
>>>> https://postgis.net/docs/postgis_installation.html#hard_upgrade
>>>> in the chapter :
>>>> "Some custom records of spatial_ref_sys in dump file have an invalid
>>>> SRID value"
>>>> Information to insert :
>>>> "Typically, if you use the french system IGN, you will have problems
>>>> with SRID values out of range. You need first to throw out completely the
>>>> IGN from the sql which is resulting from postgis_restore.pl. So, first
>>>> run :
>>>> perl utils/postgis_restore.pl "/somepath/olddb.backup" > oldbb.sql
>>>> then
>>>> grep -v IGNF olddb.sql > olddb-without-IGN.sql
>>>> then create your newdb, activate the required Postgis extensions, and
>>>> insert properly the french system IGN with this script :
>>>> https://raw.githubusercontent.com/Remi-C/IGN_spatial_ref_for_PostGIS/master/Put_IGN_SRS_into_Postgis.sql
>>>> then, to finish, run :
>>>> psql -h localhost -p 5432 -U postgres -d newdb -f
>>>> olddb-without-IGN.sql 2> errors.txt
>>>> Thank you very much for you attention,
>>>> With best regards,
>>>> Mikhael Philippenko.
>>>> Le jeu. 8 nov. 2018 à 14:55, Michel Philippenko <michel.ing93 at gmail.com>
>>>> a écrit :
>>>>> Hello,
>>>>> I'm new with Postgis.
>>>>> I'm upgrading a database from Postgis 1.5.1-5 to 2.3.1 following the
>>>>> instructions given on this web page :
>>>>> https://postgis.net/docs/postgis_installation.html#hard_upgrade.
>>>>> The errors below are displayed when importing my dump. Will my DB work
>>>>> well ? Should I fight more to have no errors at all ?
>>>>> Thank you for your help and your attention.
>>>>> With best regards,
>>>>> Mikhael.
>>>>> ERREUR: la famille d'opérateur « btree_geography_ops » existe déjà
>>>>> pour la méthode d'accès « btree »
>>>>> ERREUR: la famille d'opérateur « btree_geometry_ops » existe déjà
>>>>> ERREUR: la famille d'opérateur « gist_geography_ops » existe déjà
>>>>> pour la méthode d'accès « gist »
>>>>> ERREUR: la contrainte de vérification « spatial_ref_sys_srid_check »
>>>>> est rompue par une ligne
>>>>> ERREUR: n'a pas pu créer l'index unique « spatial_ref_sys_pkey »
>>>>> DÉTAIL : La clé (srid)=(999954) est dupliquée.
>>>>> My translation in English :
>>>>> ERROR: the operator family « btree_geography_ops » already exists for
>>>>> the access method « btree »
>>>>> ERROR: the operator family « btree_geometry_ops »already exists for
>>>>> ERROR: the operator family « gist_geography_ops » already exists for
>>>>> the access method « gist »
>>>>> ERROR: the constraint check « spatial_ref_sys_srid_check » is broken
>>>>> for one line
>>>>> ERROR: could not create the uniq index « spatial_ref_sys_pkey »
>>>>> DETAIL : The key (srid)=(999954) is duplicated.
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>>> Darafei Praliaskouski
>>> Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190718/c92fc2f3/attachment.html>
