[postgis-users] raster regions
Joao Cordeiro
joao.cordeiro at inpe.br
Fri Jul 19 06:18:22 PDT 2019
Em 18/07/2019 10:12, Pierre Racine escreveu:
> What is your goal : to simplify the queries expression or to optimize
> the processing time?
The goal is a bit theoretic, focused on gainning expressiveness for
query languages, by joinning both query and a map algebra language
together. so that regions in the raster side could be identified by
algebraic expressions. Some topological assumptions must be considered
so the nine-interceptions method can be applied with no format
conversion. I guess PostGIS can be a platform to go around the issue.
> Yes it would work with touch as well.
> At some point you have to convert pixels to something that is
> comparable with vector. The point is to lower this conversion to the
> minimum. The trick in PostGIS it to tile everything so that only
> required tiles are converted. You could certainly have some better
> algorithms than what ST_Intersects(d.geom, e.rast) is doing to process
> at the pixel level instead of at the tile level.
> Pierre
> *De :*Joao Cordeiro <joao.cordeiro at inpe.br>
> *Envoyé :* 17 juillet 2019 10:30
> *À :* Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> *Objet :* Re: [postgis-users] raster regions
> Hi, Pierre,
> Thanks, I appreciate your replies .
> That is quite a clear and readable solution to describing an
> i*ntercepting* situation. Should it work with *st_touch *as well?
> Without any raster-vector conversion for the data? My "consume dream"
> is to have it all in a single query expression, in which the SQL
> parser delegates to a map algebra parser the evaluation of a kind of
> "pertinence criteria" to regions described through "map algebraic"
> expressions. I guess, usinga binary representation to "identify" the
> regions will allways break an user question into two! For instance, a
> question such as "an specific natural event (such as flooding)
> touching a given municipality", would allways demmand for some
> (tricky) adequate binary data, prior to being expressed in the query
> language.
> Regards
> Em 16/07/2019 10:05, Pierre Racine escreveu:
> Right. To minimize the amount of intermediate computation you can
> add a discriminant to the first query:
> WITH floodareas AS (
> SELECT ST_MapAlgebra(rast, ‘1BB’, ‘CASE WHEN [rast] < 10 THEN 1
> ELSE NULL END’) rast
> FROM elevation e, districts d
> WHERE ST_Intersects(d.geom, e.rast)
> SELECT d.*
> FROM districts d, floodareas f
> WHERE ST_Intersects(d.geom, f.rast)
> Pierre
> *De :*postgis-users <postgis-users-bounces at lists.osgeo.org>
> <mailto:postgis-users-bounces at lists.osgeo.org> *De la part de*
> joao.cordeiro at inpe.br <mailto:joao.cordeiro at inpe.br>
> *Envoyé :* 15 juillet 2019 14:40
> *À :* postgis-users at lists.osgeo.org
> <mailto:postgis-users at lists.osgeo.org>
> Thanks, Pierre,
> It seems ok to model the query the way you showed, however, that
> implies the generation of an entire intermediate binary raster,
> just to identify the region inside the whole mapped area. My issue
> is on avoiding such intermediate data by incorporating map algebra
> expression into the same query expression, Another example, ""...
> d.geom touch (ndvi2018 < ndvi2019)" where ndvixxxx are raster data.
> Att.
> Em 15-07-2019 14:43, Pierre Racine escreveu:
> Hi,
> That could translate into something like this in PostGIS:
> 1 ELSE NULL END’) rast
> FROM elevation
> SELECT d.*
> WHERE ST_Intersects(g.geom, f.rast)
> NULL becomes nodata values. You could also use ST_Reclass()
> instead of ST_Mapalgebra().
> Pierre
> <mailto:postgis-users-bounces at lists.osgeo.org>> *De la part
> de* Joao Cordeiro
> *Envoyé :* 15 juillet 2019 10:19
> *À :* 'PostGIS Users Discussion'
> <postgis-users at lists.osgeo.org
> <mailto:postgis-users at lists.osgeo.org>>
> *Objet :* [postgis-users] raster regions
> Hi there,
> I am not actually a POSTGIS user, or developer, although I am
> doing some research of integration of vector -raster in a dbms
> context. My main question s about identifying regions
> represented in a domain like the "hybrid raster" so that they
> can be referred to in a query. For example, I would like to
> write something like "/*select d from districts where
> d.geometry touches flooding*/", where "flooding" indicates an
> expression intended to decide on the pertinence of locations
> to a flooding risk area described, for instance through map
> algebra.
> Thanks for any hints or suggestions.
> Att.
> postgis-users mailing list
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190719/fdc54726/attachment.html>
