[postgis-users] fail to upgrade from 2.1.8 to 2.2.2 or 2.3.3
olivier.lobry at umontpellier.fr
Thu Jun 27 03:46:03 PDT 2019
Hi
Thank you for the suggestions.
I’ve finally found that the problem lies in the creation of the temporary _postgis_upgrade_info table :
241 CREATE TEMPORARY TABLE _postgis_upgrade_info AS WITH versions AS (
242 SELECT '2.2'::text as upgraded,
243 postgis_scripts_installed() as installed
244 ) SELECT
245 upgraded as scripts_upgraded,
246 installed as scripts_installed,
247 substring(upgraded from '([0-9]*)\.')::int * 100 +
248 substring(upgraded from '[0-9]*\.([0-9]*)\.')::int
249 as version_to_num,
250 substring(installed from '([0-9]*)\.')::int * 100 +
251 substring(installed from '[0-9]*\.([0-9]*)\.')::int
252 as version_from_num,
253 position('dev' in installed)::bool
254 as version_from_isdev
255 FROM versions
256 ;
at line 248, substring(upgraded from '[0-9]*\.([0-9]*)\.’) cannot be cast to int since it leads ‘’ because of the « SELECT '2.2'::text as upgraded » at line 242.
replacing SELECT '2.2'::text as upgraded with SELECT ‘2.2.2'::text as upgraded solves the issue
Looks like there is the same problem with any migration scripts from 2.1.xx
Maybe a problem of compilation/debian distribution (since I installed postgis using debian packages) ?
Regards
Olivier
> Le 26 juin 2019 à 13:00, Sandro Santilli <strk at kbt.io> a écrit :
> On Wed, Jun 26, 2019 at 11:20:59AM +0200, olivier.lobry at umontpellier.fr wrote:
>> Hi,
>> On a postgresql 9.3 / postgis 2.1.8 / debian 8.11, I cannot upgrade postgis to 2.2.2 (or 2.3.3) :
>> # ALTER EXTENSION postgis UPDATE TO '2.2.2';
>> WARNING: nonstandard use of escape in a string literal
>> HINT: Use the escape string syntax for escapes, e.g., E'\r\n'.
>> ERROR: invalid input syntax for integer: « »
>> Any idea of what happens ?
> Note that latest PostGIS version in the 2.2 branch is
> 2.2.8 (released on 2018/11/21) and latest in the 2.3 branch is
> 2.3.8 (released on 2019/03/11).
> Also, latest stable is 2.5.2 (released on 2019/03/11)
> Before moving on, I'd try *those* upgrades.
>> How can I get more debug information ?
>> Is it possible to execute the command step-by-step to see where the underlying script fails ?
> Not with the "EXTENSION" mechanism, but you could try the
> script-way, using psql -f which would give you a line number
> of the failing statement.
> Please show the output of `SELECT postgis_full_version()" issued
> on your 2.1.8 install, and beware that a newer release in the 2.1
> branch of PostGIS is also available: PostGIS 2.1.9 (2017/09/19)
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
