[postgis-users] PostGIS + pgdump
Sandro Santilli
strk at kbt.io
Mon May 20 05:48:02 PDT 2019
On Mon, May 20, 2019 at 12:35:40PM +0000, Zwettler Markus (OIZ) wrote:
> You also think the errors are due to the version mismatch.
Is that a question ? If it is, my answer is: NO.
ERROR: relation "geometry_columns" already exists
It means PostGIS is already installed in the target DB, and you're
trying to install it again.
> We should da a hard upgrade with postgis_restore.pl to avoid this errors. Correct?
You can try, and report errors here, if any.
--strk;
