[postgis-users] PostGIS + pgdump
Zwettler Markus (OIZ)
Markus.Zwettler at zuerich.ch
Mon May 20 05:35:40 PDT 2019
Hi Sandro,
You also think the errors are due to the version mismatch. We should da a hard upgrade with postgis_restore.pl to avoid this errors. Correct?
<quote>
The dump/reload process is assisted by the postgis_restore.pl script which takes care of skipping from the dump all definitions which belong to PostGIS (including old ones),allowing you to restore your schemas and data into a database with PostGIS installed without getting duplicate symbol errors or bringing forward deprecated objects.
</quote>
Seems to be safe to ignore this errors. Correct?
Markus
