[postgis-users] Counting intersecting polygons
Eduardo Ramos
duda.ramos at gmail.com
Wed May 29 00:38:54 PDT 2019
You can use the blue polygon centroid to intersect the green layer.
Best regards,
Eduardo
> On 28 May 2019, at 18:47, Marcin Mionskowski <mionskowskimarcin at gmail.com> wrote:
> I checked on the larger tables - you're right. Your approach
> significantly speeds up the query. Nice hint - thanks!
> W dniu wto, 28.05.2019 o godzinie 08∶36 +0200, użytkownik Arnaud L.
> napisał:
>>> Le 27/05/2019 à 14:47, Marcin Mionskowski a écrit :
>>> SELECT COUNT(DISTINCT t1.column_with_unique_ids)
>>> FROM Table_1 t1
>>> ,Table_2 t2
>>> WHERE ST_Intersects(t1.wkb_geometry,t2.wkb_geometry)
>> Unless you're running PG12 and PostGIS 3 (see Paul Ramsey's latest
>> post), the "WHERE EXISTS" construct will be able to trigger a
>> parallel
>> query plan whereas the "JOIN" construct will not.
>> Cheers
>> Arnaud
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
