[postgis-users] Looking for information for allowing Office 365 Excel to access and use map data stored on PostGIS.
Stefan Wolf
sw at zpmt.de
Tue Nov 12 04:58:05 PST 2019
Google for: odbc pass through query
SQL pass-through queries are used to send commands directly to an ODBC database server. By using an SQL pass-through query, you work directly with the server tables instead of having the Microsoft Jet database engine process the data.
You can use “normal” PostgreSQL-SQL syntax like in pgAdmin…
Regards
-Stefan-
Von: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] Im Auftrag von Shaozhong SHI
Gesendet: Dienstag, 12. November 2019 13:26
An: PostGIS Users Discussion
Betreff: [postgis-users] Looking for information for allowing Office 365 Excel to access and use map data stored on PostGIS.
Has anyone got such information?
Looking forward to hearing from you.
Regards,
Shao
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191112/0339b036/attachment.html>
