[postgis-users] Looking for information for allowing Office 365 Excel to access and use map data stored on PostGIS.
Tahir Tamba
tahir.tamba at gmail.com
Tue Nov 12 07:02:19 PST 2019
Nice to hear some folks with experiences on that feature...
Regards,
Le mar. 12 nov. 2019 à 08:10, Stefan Wolf <sw at zpmt.de> a écrit :
> Google for: odbc pass through query
> SQL pass-through queries are used to send commands directly to an ODBC database server. By using an SQL pass-through query, you work directly with the server tables instead of having the Microsoft Jet database engine process the data.
> You can use “normal” PostgreSQL-SQL syntax like in pgAdmin…
> Regards
> -Stefan-
> Von: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] Im Auftrag von Shaozhong SHI
> Gesendet: Dienstag, 12. November 2019 13:26
> An: PostGIS Users Discussion
> Betreff: [postgis-users] Looking for information for allowing Office 365 Excel to access and use map data stored on PostGIS.
> Has anyone got such information?
> Looking forward to hearing from you.
> Regards,
> Shao
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
