[postgis-users] postgis version consistency issue
olivier.lobry at umontpellier.fr
Fri Nov 22 01:52:54 PST 2019
Hi
It looks like I have installation issues with postgis.
I recently upgrade from pg 9.3 / postgis 2.2.x to pg 11 / postgis 2.5.2
But I now have some issues with some Postgis functions. For instance :
SELECT
st_collect(t.geom) AS geom
FROM
a_table t
rises :
ERROR: could not access file "$libdir/postgis-2.4": No such file or directory
SQL state: 58P01
It seems it looks for version 2.4, while 2.5.2 is installed :
$ dpkg -l | grep postgis
ii postgis 2.5.2+dfsg-1~exp1.pgdg90+1 amd64 Geographic objects support for PostgreSQL
ii postgis-doc 2.5.2+dfsg-1~exp1.pgdg90+1 all Geographic objects support for PostgreSQL -- documentation
ii postgresql-11-postgis-2.5 2.5.2+dfsg-1~exp1.pgdg90+1 amd64 Geographic objects support for PostgreSQL 11
ii postgresql-11-postgis-2.5-scripts 2.5.2+dfsg-1~exp1.pgdg90+1 all Geographic objects support for PostgreSQL 11 -- SQL scripts
$ psql -d OSU -c "SELECT PostGIS_full_version();"
postgis_full_version
POSTGIS="2.5.2 r17328" GEOS="3.5.1-CAPI-1.9.1 r4246" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.1.2, released 2016/10/24" LIBXML="2.9.4" LIBJSON="0.12.1" TOPOLOGY RASTER
And what is strange is that \dx gives version 2.1.3…
whereas postgis_topology is ok
why ??
$ psql -d OSU -c "\dx"
List of installed extensions
Name | Version | Schema | Description
postgis | 2.1.3 | public | PostGIS geometry, geography, and raster spatial types and functions
postgis_topology | 2.5.2 | topology | PostGIS topology spatial types and functions
If I try to upgrade I obtain this error :
$ psql -d OSU -c "ALTER EXTENSION postgis UPDATE;"
ERROR: function "st_union(geometry)" does not exist
LINE 2: WHERE oid = 'st_union(geometry)'::regprocedure AND proparal...
QUERY: UPDATE pg_proc SET proparallel = 's'
WHERE oid = 'st_union(geometry)'::regprocedure AND proparallel = 'u'
CONTEXT: PL/pgSQL function inline_code_block line 5 at SQL statement
Anyone know how I can fix this version consistency issues and have a clean installation ??
Thank you for your help
Regards
Olivier
Olivier Lobry
Ingénieur de Recherche
Chargé du Système d'Information
OSU OREME
UMS 3282 CNRS - UMS 223 IRD
www.oreme.org <http://www.oreme.org/> / data.oreme.org <http://data.oreme.org/>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191122/87dec7ef/attachment.html>
